Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Dish washer wont drain
The dish washer wont drain is eight years
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 25, 2010
Dishes and glassware are filmy after the cycle. There is salt in the washer.
Probably not draining properly so wont rinse.Put end of drain hose into bucket to check,you should get a good flow.
Mar 07, 2015 | Thermador Dishwashers
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
GET ERROR CODE f-2, AND IT WONT DRAIN THE WATER kENMORE ELITE hE3T
It is a code for a long drain problem (more than eight minutes). Press the Pause/Cancel button twice to clear the display. When the display is clear, press the Drain & Spin button then select No Spin by pressing the Spin Speed button, and then press and hold the Start button to start draining the water.
Use your senses to check whether the drain pump is running or not. The drain pump is located at the front right bottom of the machine. Check the volume of water being discharged to the drainage.
Disconnect power to the washer and check the drain hose for clogs and kinks, and then repeat the No Spin draining process, if the drain pump is running and water is being pumped out, until the water is completely drained out of the washer. Just press the Pause/Cancel button twice when the code appears to clear the display and restart draining.
Make sure the drain hose is raised no more than eight feet above the floor where the washer is installed. The drain pump cannot pump the water properly out to the drainage more than eight feet above the floor.
When draining is complete, empty the machine then prop up the bottom front edge of the washer to allow easy access to the three screws attaching the lower front access panel to the cabinet. Remove the screws, and then push the panel down and off the cabinet to access the drain pump.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter for any debris that might be causing the pump to work poorly then screw it back in place.
Slide the lower front access panel up back into the cabinet and secure it the three screws.
Mar 12, 2010 | Washing Machines
Dishwasher seems to be clogged, wont drain
I had the same problem and it was solve by checking the food disposal were the dish washer is usually attached for draining, if you resently replaced the disposal it could be that the drain hold was never openned. I hope this helps
Apr 22, 2009 | Dishwashers
Kenmore dish washer wont drain
Those are Chinese massage balls. You place them in your palm and rub them together and the result is a "calming" effect, which are ingeniously placed their by the courteous engineers at Kenmore to help you relax while you perform the self-repair. Just kidding. I had the same problem and learned that they are called "float balls". There should a small hole where the water comes up and drains - they are placed in that hole.
Nov 14, 2008 | Dishwashers
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
179 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
