Question about Microsoft Xbox 360 Console
Hard Drive, AGAIN >.<
So, my friends. I have gotten the E68 error more then once. But, i found a way to fix it...but that way is throwing at a wall. yeah, i know sounds stupid. But it worked, so don't judge me. Anyways, now...i've gotten it. AGAIN...and i really would rather not throw it at a wall again. If you know what i mean.Any suggestion's on how to fix it?
Have you tried cleaning the connection ports ?
Posted on Apr 24, 2010
    Sergeant:
    Champion:
  • 242 Answers
Every tried removing the hard drive? Then seeing if it works? If it does then buy a new hard drive off of ebay or something.
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works&lt;did that twice&lt;the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
XBOX System error E68
my friend suffered like these doubts....... he cleared his problem with the help of xbox 360 repair guide...... click here for your reference
May 08, 2010 | Microsoft Xbox Console
The xbox360elite the red light flashes and e68 comes up on the screen with different language on the tv screen is also showing.
E68 means that you have a bad hard drive. Take out your hard drive and turn the unit on to confirm. Once this is done just buy a new hard drive and your good to go! Or now Microsoft just released where you can use a Flash drive :]
Apr 05, 2010 | Microsoft Xbox 360 Elite Console
I have a e68 on my xbox 360 what can i do to fix it
e68 is an easy fix, one that shouldn't even be charged for.
ok, so let me tell how it's going to work, the E68 means that your HDD needs to be updated,
so you have to get to http://www.xbox.com/en-US/support/system… ,
and then download the update file, and uncompress it ,
then rip it on a disc or a DVD,
then just set your 360 to Boot to disc from System----> console Settings------> Startup
then put the disc in the 360 , then turn it off,
and attach the Hard Drive
then turn it back on and the 360 will apply the update to the Hard Drive,
and if it didn't work your Hard drive may need to be replaced.
Jan 17, 2010 | Microsoft Xbox 360 Console
1 red ring E68
The single red light on the Xbox shows that there is a hardware failure.
The E68 error is linked to a problem with the Xbox 360 Hard drive. Try removing the hard drive from the Xbox and attempt to use the Xbox again.
If the error does not occur when the hard drive is not connected then you will need to replace the hard drive.
If the error still occurs then the console will need to be repaired.
Nov 17, 2009 | Microsoft Video Game Consoles & Games
On my xbox360 i got the e68 error message and i took the hard drive out, and then put it back once the xbox was on and i went to memory on the system settings and for my main profile it said corrupted...
can you still access anything else that was saved on your hard drive?
such as demos or anything else you downloaded, etc? generally that means your hard drive has over heated, or worse, crashed. but! you got lucky that your whole xbox didn't crash with it. there is a chance you can save your hard drive and all your files. there is a how to here: http://ezinearticles.com/?Xbox-360-E68-Error-Fix&id=2549596
Aug 06, 2009 | Microsoft Xbox 360 Console
E68 error on xbox 360 HELP PLEASE
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
E68
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well
more information can be found at http://support.microsoft.com/kb/917874
Nov 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
