Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
THE FRIDGE WILL RUN FOR A WHILE WHEN YOU HIT THE
THE FRIDGE WILL RUN AND START COOLING AGAIN FOR A WHILE WHEN YOU HIT THE CONTROL PANEL KNOBS, THEN SHUT OFF LATER ON BUT IF YOU HIT THE AREA NEAR THE KNOBS IT WILL START UP AGAIN.
    Sergeant:
  • 239 Answers
Change the cold control
Posted on Apr 25, 2010
I have a clicking sound coming from the control panel, and freezer and fridge are not cooling well. Any ideas?
The clicking sound might be from the knob you turn in side the refrigerator, it is hidden. You open fridge door and there is a hole in the under side, probably to left of the temp control knobs, this one has to be turned with a screw driver and you turn it un till it turns off while it is running the cooling system I mean. Once it turns off you turn it counter clock wise just a lil bit. And watch it turn on again on its own, and stay there to make sure it shuts off as well on its own.. if it don't turn off try it again to the right the a lil to the left. Between cycles. This is a timer for the cooling system how long it stays on
Nov 25, 2017 | GE Refrigerators
Moved gorenge fridge freezer today about 2m and now light is on but not starting up
Nov 25, 2017 | Refrigerators
How can I get my Amana fridge and freezer working again? My lights were off for two weeks, and now it's not cooling, but the light is on.
Thermostat might be stuck. My fridge stopped working recently and I hit the thermostat control a sharp blow with the handle of a soft-handled screwdriver and it started to work again.
I had to hit it several times over the next few days to keep it going until the new thermostat arrived but since it was delivered the fridge has been working normally...
Sep 06, 2017 | Amana Refrigerators
Refrigerator part of coil freezing up, what would be the problem?
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Jul 25, 2013 | Refrigerators
Why is my frigidaire model # plrs267zab7 not cooling?
Have you adjusted the cooling control knobs.
Is the fridge fairly empty
Is the fridge in the garage in cold weather
Nov 15, 2010 | Frigidaire Refrigerators
Not cooling/freezing
Hi!!
Check
temp. control knobs,
Small fan in freezer, it should start working after opening the freezer door for a couple of minutes. If it does not start, use a pen or pencil to turn the blades, if it kick in, replace motor.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear.
Once this is done, restart unit
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Frigidaire Refrigerators
My refrigerator is running good but not freezing or cooling
Hi!!
Check
Don't forget to rate this post!! Good Luck!!!
Jul 19, 2010 | Kenmore Refrigerators
Stops cooling (fridge and freezer) then starts again
if turning the temp control up and then back down turns it back down, you might start with the thermostat. unless you have a local shop you like i recommend. http://www.appliancepartspros.com/partsearch/
Aug 17, 2009 | Frigidaire FRS26R4A Side by Side...
I have a Dometic fridge with cooling issues.
theese wire that goes to the fins are your thermostat probes it possible that your thermostat is defective if you take your thermostat and bypass the two wire connected to it toghether if your fridge works replace the thermostat thanks from gilles
Mar 07, 2009 | Dometic RM2652 Refrigerator
Kenmore side-by-side stops cooling
hi thanks for the question if you turn the controls and then it starts i would replace the cold control if this part fails it will allow the fridge to get cold but not come back on just tapping the control will get it going again replace the cold control thanks the appliance doc
Sep 22, 2008 | Refrigerators
Refrigerators Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
