Question about Aiwa Audio Players & Recorders
Aiwa nsx-3200 won't play cd's. It spins then stops and tries to go to another cd then repeats the process
5 Suggested Answers
SOURCE: Aiwa NSX-V70 will not recognize
Hi there. Found your post as I was looking for an answer to the same issue with my NSX v70 about an hour ago. I'm pleased to say that I found a solution on the web and mine is now working fine!
Try this address below and follow the instructions. The knob you need is black, with some white numbers on and can be seen from the back of the unit once you have removed the black casing and the silver back. Quite easy when you know how! Good luck.
http://www.kuro5hin.org/story/2004/3/24/45212/6874
Posted on Aug 06, 2008
VOTIT
  • 2071 Answers
SOURCE: Aiwa NSX-SZ10, reacts to all
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 07, 2008
tech48
  • 624 Answers
SOURCE: my aiwa nsx-r50 keeps switching
This is probable the protect mode, you may have a bad channel in the amp or a bad speaker. Try it without the speakers connected and let me know if it still shuts off.
Posted on Feb 06, 2009
mlapres
  • 757 Answers
SOURCE: My Aiwa NSX-999mkII keeps switching off
Without speakers indicates that it is shutting off due to thermal protection. Do not store anything on top of it, especially any device that has heat of it's own and give it plenty of air space all around it, at least 6 inches.
Posted on Jun 18, 2009
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
May 28, 2009 | Audio Players & Recorders
Cd's won't play
this happence because of reeding error.out of focus of lence .please change the picup.
nuwan.
Jan 12, 2009 | Aiwa NSX-AJ20 CD Shelf System
CD-R Playback Issue
check the laser eye of your player clean or replace.
Aug 28, 2007 | Aiwa NSX-A115 Shelf System
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
287 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
