I change the settings on my samsung 71 series, and as soon as I turn off the tv the settings return to the way they were in the store. What am I doing wrong? why does it not save my changes?
  • 59 Answers
After you have changed the settings, you must go to "user reset" push "enter" two more times, then power off your TV. When you turn your TV back on your setting should be saved.
Posted on Mar 23, 2008
SOURCE:
How do I get the promo display off my screen on a Samsung PDP TV series 4+ 600hz
For this model, you will need to reset the TV and go through the first time set up again. To do this, use the remote when the TV is turned off and push mute, 1, 8, 2, power in that order. The service menu will come up. Select options, then factory reset. The set will then power off. Turn the set back on and go through the first time set up, making sure you pick home and not store. Hope this helps.
Apr 09, 2016 | Samsung Televison & Video
I have anew Samsung 55 inch model code ue55h6500akxxu but it will not store my settings as soon as i turn tv off an on again it goes back to custom settings
This is from an article I found online:
"It's likely that the television is in Shop Mode. The symptom would be that your settings are defaulted back to the out-of-box settings?
Try holding down the Menu button on the TV (Not remote) for 12 seconds.
OR
Try pushing the volume button up once, let go, and then hold down the MENU button for about 12 seconds.
You might see the screen flicker, and that's okay. Once you've done that, you should be able to program your settings and they should stay.
--HDTech"
Feb 02, 2015 | Samsung Un55c6400 55 Inch Led Hd Tv - Free...
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
The picture setting keeps returning to retail store setting
Go back to the store you bought it from. They sometimes lock them.
Mar 25, 2010 | Philips 32PF5531D 32 in. LCD Television
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Aug 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Brightness keeps shifting on Samsung 46" 7 Series 750
I just purchased Samsung series 4 LCD TV yesterday. I had the same problem since my salesman was a kind of stupid. He set the 'Power save mode' to automatic. After fiddle with my TV for a while, I found the solution.
Just change the 'Power save mode' to off, low, normal or high. My LCD TV stopped shifting its brightness.
Jun 23, 2008 | Televison & Video
Don't store tv setting LCD40F86BD
im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Jun 12, 2008 | Samsung LE40R74BDX 40 in. LCD Television
When i turn the power on it looks like the tv is going to come on but the lamp lite (on display) blinks and then goes out. the screen takes a little bit of a glow but no picture. all display lamps go out...
The place you purchase the set from has to help you or guide you in the right direction so you get the set service, if they dont tell them you will bring the setback to them for a refund or exchange,the manufacture is the responsible one but stores also have something to do.
Oct 01, 2006 | Samsung HL-R7178W 71" HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Ekse
