Question about HP Compaq nx6110 PC Laptop
My Hp laptop freeze at Startup
My laptop ran out of battery after i charged and try to turned on but the only thing i see is in the middle of the screen and< Press ESc to startup> in the left hand corner . I tried to press esc but it just freeze after that . I have tried to press F8 F10 but nothing happens
  • 1 more comment
  • tran_thuy984 Apr 25, 2010
    i dont know where is the hard drive ... Can u tell me or describe ... what is it symbol ??
    okay i did find and remove the hard drive but it still have the same problem
    sorry when i press those button it either frozen or make a noise .... So what should i do ??
  • 1,472 Answers
Tran_thuy984
Try clearing the flee power off the system. To do this unplug the AC Adapter and battery from your notebook. Next hold down the power button for 30 to 45 seconds. After that plug back in the AC Adapter and turn on your notebook. It should boot normally.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Apr 26, 2010
  • 369 Answers
1. shut down the laptop and disconnect it from power cord. 2. Remove the battery. 3. Hold down the power button for 30 seconds. 4. Connect the power cord and try to turn it on. 5. Now at the start up try F8 and choose safe mode with networking. 6. Else, at the startup press F2(Delete or F1) to go to BIOS and set BIOS to default settings. Hit F10, ESC once and choose Save and Exit and hit enter. 7. If all of this does not work, you can try to reset your computer to factory setting by hitting F10 or F11 at the startup.
Note: This process would delete all of the data of the computer. 8.If this all also does not work, please try to reinstall the operating system.
Posted on Apr 25, 2010
  • HP Master
  • 13,433 Answers
Hi
try taking out the battery and the power cable for 5 minutes, then hold down the power button for 60seconds, then reconnect the battery and plug in.
Turn on the computer, if you are still unable to start up the computer, try pressing TAB key on the left(below 1, next to Q) and see if anything comes up.
if noting is coming, up.. well try a few times , turn off, turn back on, press TAB a few times and see if it gives you anything.
If you are still stuck there. Remove the battery and power adapter.
now first check, are you in warranty or not? if you are in warranty, stop here.
I you are outside of warranty, lets start narrowing down the problem, in the bottom of the laptop you should have few covers, one of them will store a wireless card, one of them will store your ram memory cards and the last one should have Your hard drive, you need to remove the hard drive from the computer.
Once you have done so, plug in and start the computer, if it goes past the screen where it froze previously, (you will still get a black screen, with blinking cursor) then most likely the hard drive is the issue, put back the drive and if the issue comes back, then its definitely the hard drive.
if noting happens when you remove the hard drive, then its not the problem, do you have a recovery option on the screen when you turn on? Try doing recovery.
Let me know how it goes when you have gotten this far.
Posted on Apr 24, 2010
  • Ekse Apr 25, 2010
    from what you have posted it sounds like there is a hardware problem in the laptop, most likely the motherboard, you need to take it to a repairer to get a repair estimate. if you are in warranty contact your dealer for warranty repairs.
    no magic fix today.
Battery power
Is the battery charged? Looks like you try to startup the laptop with a discharged battery.
Dec 07, 2013 | HP Compaq nc6220 Notebook
Sir, toshiba laptop doesnt startup,even no msgs comeup no cmos msgs also..after switch on..need help,,thx,bye
What is the status of the light on the adapter? That would be the first thing I would check. It may be possible that your battery ran out and due to bad adapter its neither charging nor powering on from the outlet. If the adapter is working fine, then let me know and we will look at the other possibilities
Sai.
Nov 02, 2010 | Computers & Internet
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Will not turn on, last time used, I turned it off manually?
Try this:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | HP Pavilion DV6500T Notebook
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv1000/won't turn on
My HP laptop ran out of juice and wouldn't charge. It was the power connection on the mother board. A computer guy resoderd (sp) it for me and then it would turn on and charge the battery. Not sure if that helps.
Jul 17, 2008 | Computers & Internet
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
Startup problems
Have you considered it could be the battery has died. Have you tried external power? If the battery is OK then check the battery contacts to make sure they are clean. Has your power supply died and it won't power the laptop or charge the battery? It could be the motherboard but I'd put my money on it's power supply or battery. Without more details being supplied.
Jul 20, 2006 | HP Compaq Motherboard
HP Compaq nx6110 PC Laptop Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
