Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Turn off beeping alarm when the coffee maker is done brewing
I want to silence the beeping on the coffee maker. When the coffee maker is done brewing it sounds an alarm...i would like ot disable it. Please help!
  • 2 more comments
  • Anonymous Aug 25, 2008
    This [email protected]  We have the same problem and its annoying.
  • supersipper Sep 01, 2008
    Your pot should have an on/off slider switch to the left of the heat plate temp knob. Slide it to off and that should take care of the problem.
  • Anonymous Mar 23, 2014
    The coffee maker beeps (like it's done) immediately after pressing brew. It doesn't actually brew any coffee.
  • Anonymous Mar 24, 2014
    I have turned my coffee maker on and it just won't brew. Unplugging and plugging back in has not done anything.
    Genius:
  • 1,554 Answers
You can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • Martin Joseph Nov 10, 2017
    Actually you can, if you are stubborn enough.
    New Friend:
  • William Powers Oct 22, 2013
    Mine should beep when brew completes and again 2 hours later. Instead it beeps after about 1 minute into the start of the brew ( and again 2 hours later). Anyone know how to fix it? thanks
    New Friend:
It's so totally safe to disable the alarm by yourself, you need some screwdrivers and a pair of pliers to do it, I got it right on the first try so I made a how-to video. Turning off your Alert Alarm on your Mr Coffee Coffee Maker Mod JWX23
Posted on Dec 30, 2015
SOURCE:
Keurig makes clicking sound but will not brew
The exit tube is clogged. Get a paper clip and straighten one end, pushing it up into the tube to clear the material out. The tube is the upper Pin Like projection that pierces the Kcup.
Jan 25, 2014 | Keurig Elite B40 Coffee Maker
Beep like its done
It sounds like the coffee exit needle is blocked. Take a small paperclip and carefully insert upward into exit needle, swirl to dislodge debri. Do this for all three of the holes in the exit needle.
Run "Brew" without a KCup to see if this clears the exit needle.
Nov 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
Set the timer to start brewing, i have always done this with no problem till now
Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Apr 07, 2011 | Coffee Makers & Espresso Machines
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Doesn't complete a full brew cycle before alarm sounds to indicate end of brew cycle. Have to re-start up to 4 times to get a full pot of coffee.... what can be done to solve this issue?
sorry I don't have a solution but actually have the same problem. This is driving me crazy! (not really) I have tried taking the filter out and cleaning the unit with vinegar. nothing helps.
Aug 22, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
10,477 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Pierre Laplante
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
