Question about Maytag MDE9700AYM Electric Dryer
My dryer may have a grounding short. A current is flowing thru the vent tub and is causing sparks. I can not find the short. Any ideas?
  • 64 Answers
You could try unpluging the wires around the vent with power turned off then plug them back in one at a time turn power back on each time. When you get the spark back it's in the circuit that was pluged in last. Hope this will help you
Posted on Apr 24, 2010
Yamaha grizzly
Yes. Loose connection. Current still tries to travel, must jump thru space creating sparks which generate heat causing burn marks.
Aug 06, 2013 | Motorcycles
I have a maytag dryer DE882. The dryer blows warm air but does not dry clothes. Any ideas what could be the problem.
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 18, 2012 | Maytag Dryers
Kenmore dryer model #110.62612101
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes;
May 17, 2012 | Kenmore 74112 Gas Dryer
Indesit IS70C tumble dryer not heating
May 10, 2012 | Indesit IS70C Electric Dryer
Our T9800 miele dryer loses electricity and shuts off. It has has happened before and the it came back on. We are not sure why it goes out or why it comes back on. Any ideas ? We know it's not a...
Hi and welcome to FixYa, I am Kelly
What your describing is probably an air flow problem. Pull off the rear vent connect and start the dryer on no heat first. The air-flow should be strong enough to push a relaxed hand and wrist gently a short distance away form the outlet. IF you do not have this kind of air flow the apr passages inside the dryer are clogged with lint.
The passages that need attention
1. The lint filter. Wash it with vinegar and water then soap and water. Dryer sheet particulate or clothing will clog the screen. It wil look clear / clean but, it can be totally blocked.
2. The lint filter cavity remove the lint filter and use a folded wire coat hanger in a U shape to assist in removing lint while using a vacuum to get rid of the lint.
3. Use a flashlight and check the exit vent on the back of the dryer for a white / gray restriction of lint build up. Ust the folded wire coat hanger to assist in clearing the ducting.
4. ANYWHERE you can access ducting clear it.
5. Make sure to check all of the ducting from dryer to the vent flapper outside the house. The thru the wall vent flapper is on of the most common reasons for vents being blocked.
After the serious cleaning session re-test the outlet on no heat to see if it will push your hand and wrist gently away from the vent outlet. If you have good air flow reconnect the vent and check air-flow outside the home at the thru the wall vent. It should be very brisk.
If you can not establish good air flow then there is a problem with the fan / blower wheel. It is most likely damaged. Broken blades, center hub cracked and the wheel is more or less floating on the motor shaft.
This should resolve the problem BUT if it does not respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Miele T9800 Electric Dryer
I have a Maytag Quiet Plus ll Model # MDE9806AYW. We found water in the dryer vent. Do you have any idea what could be causing this?
A plugged outlet vent. Start the dryer and go outside and check the vent. It should have a strong air flow. It the air flow is not strong check all the vent tubing and the outside vent.
May 31, 2011 | Maytag Dryers
Ok, checked fuse on my gas dryer and it is blown. thanks for the tip, but if the fuse is blown, does that mean that there is a problem elsewhere causing the fuse to blow?
Most fuse issues are caused by vent restrictions. Also, the element being shorted to ground can cause the fuse to blow. Make sure the vent is clean and air flow is good. Look at the element to be certain it is not shorted to ground.
Kelly
Mar 23, 2011 | Dryers
No heat
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 02, 2009 | Kenmore Dryers
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
GFI
Hello Joesal,
A GFI receptacle senses and imbalance between the hot ( line voltage) feed and ground. There should be no current sensed on the ground. This protection feature will disable the line voltage in milliseconds if it sense current passing thru to ground. The intent is to sense current flow to ground and in the event that you are that path ( meaning current is flowing thru you as a ground)..it disables that line voltage in milliseconds to keep you from being electrocuted. You have either a bad GFI receptacle or there is leakage current getting thru to ground. In either case, its a good idea to determine which is the problem.. I suggest you try your coffee maker on another GFI receptacle in your home ( perhaps in the bathroom or basement) to verify the coffee maker isn't malfunctioning. If it is,, then you may want to discard it or if you are elecrically handy, repair it,... Do not compromise you or your familys safety with these things.. Be careful and good luck..
In addition,if you do run the coffee maker off an extension cord, make sure it is properly sized for the current that your coffee maker requires.. I wouldn't use any extension cord less than 14 gauge ( #14 )
Good Luck..
Oct 01, 2008 | Waring Pro WC1000 Coffee Maker
Maytag MDE9700AYM Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
