Question about Sanyo DP37647 37 in. LCD TV
My tv broke
I turn on the tv the little green lite comes on but theres on picture or sound
If you have comcast you can use your remote to change the setting to DVD and then change it back to cable. your picture should then come back
Posted on Apr 24, 2010
Sanyo,LCD tv, Model DP55D44.
First thing I would try is replace whatever cable you are using for the input. Or just turn the TV on and press the input/source button on the remote then move the input to see if you get anything different.
Aug 08, 2016 | Televison & Video
Why no picture, no sound?
that is stand-by problem,if u r a technician,than you check the stand-by circuit thoroughly unless you have call the customer care
Jun 08, 2015 | Sony Kdl-52vl150 52" HDTV LCD TV
Sanyo DP46819 green ind. light comes on but no screen or audio
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Jun 07, 2012 | Sanyo DP46848 LCD TV
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
No picture or sound just a popping sound when power is turned on
when I turn on the TV the green lite just flashes and when I reset it, it makes a sound like it is going to come on, but it does not have a picture
Nov 27, 2009 | Philips Televison & Video
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Green power lite blinks but does not turn solid green
check the lamp...lamp cover under front panel on left... take out lamp (unplug TV befor doing this) and see if it is broke ....if lamp is good replace it and put it back together plug set back in and try it agen some times the conector dont make good contect so just taking out and in fixes it..... also lisen to the set when you turn it on most of the time there is a little buzz when it is trying to fire the lamp if the buzz is not there it maybe the ballast board
good luck
Nov 11, 2008 | Panasonic PT-50LC14 50" Rear Projection...
I have a 56" rear projection panasonic tv when i turn it on green lite come on then a lamp lite comes on red no picture or sound lamp lite flashing
Doulbe check in the owner's manual, but this is usually an indication of a bad lamp or fan error. There will be a table in the owner's manual listing the error codes as shown by these lights. I can't give you more details without the exact model number.
hope this helps,
Dan
Sep 08, 2008 | Televison & Video
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
First looked concave Now its dead
call a tech to repair you tv it is having problem in the power supply or related circuit.good luck.
Apr 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Sanyo DP37647 37 in. LCD TV Logo
290 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
