Question about Microsoft Office 2007 Basic for PC
Y it is not getrting install - Microsoft Office 2007 Basic for PC
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
You must uninstall this Office then choice modify check in there then click install after finish you must restart your computer.good luck
Posted on Apr 27, 2010
2005 colbolt problems with power steering only works sometimes
The fans belts need to be checked to verify that they are clean and tight. The fluild needs to be checked for level and sometimes changing th fluid to new fixes some problems. there's a pressure switch that makes the powersteering work less a tspeed and it's plug and the swich can fail.After that the rack and or pump in that order. I do the cheapest stuff first. Belt , level and change fluild before getrting tinto the part wher you can get over your head quick if your not a professional mmechinic. O r need to hire one.
Oct 09, 2012 | 2005 Chevrolet Cobalt SS
What is the right fuel oil mixture???
ok im not a mind reader ,,,so what chain saw is it???? il have a go at this one,,,,,
most chain saws take a 50 to 1 mix if there not very old,,,but thats not all of them,,,ok?
some run on 40 to 1 mix,,,,old chain saws run on 25 or 30 to 1 mix? and very old saws run on 10 to 1 mix,,,,now you see you did not help me not telling me which saw you have,,, did you?
if its a new saw to be safe run it on 40 to 1 oil mix its a two strok so if there is a little smoke then its getrting oil to the bearings so it wont seze up?
Dec 02, 2010 | Garden
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
HI FISHER AND PAYKEL we have a iw 712 intuitive eco the washing machine is not filling up with cold water the tap is turned on could you tell what the problum could be. KIND REGARDS KEVEN
Hi Keven just read your posting.1st turn the cold tap off and remove the cold water hose from the machine end.Now put the end into a bucket and turn the tap on.Are you getting water out of the hose?If you are, check the little filter on the water valve that you removed the hose from and see if it is blocked.Are you getrting any cold water into the machine?Please reply with additional answers on the questions and I am sure I can help you.Looking forward to your reply.
Sep 28, 2010 | Fisher Washing Machines
Manual cata efm60ss oven
Ive had a cata efm6022 for 13 months, and its one thats used 3 times a week. On christmas day the blinking thing stopped working. Theres electric getrting to it cause the fan is working and the light. But its just blowing cold air. Any ideas would be appreciated.
Sep 24, 2010 | Ovens
Car stalls and sputters at random times, but no check engine light
U MIGHT WANT TO CHECK UR THROTTLE VALVE MAY BE FULL OF GUNK AND MAYBE GETRTING STUCK BECAUSE OF IT....CLEAN IT WITH A COMPATIBLE SOLVENT
Aug 22, 2010 | 1997 Nissan Maxima
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 | A4tech PK5
Computer screwed up0 sense installing Explorer 7
Have you now got or had before a logitech mouse,keyboard or web cam attached to your system? I have constant problems with IE7, and because of the non responsive browser, it throws up a problem with my laptop touch pad.
Jan 13, 2007 | Balance CP4401 PC Desktop
Microsoft Office 2007 Basic for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
