Question about Baldwin 3503 - Edgewater Tissue Holder
What is the distance to drill for a 24" baldwin towel bar?
  • 20 Answers
Dry fit your towl bar and measure center to center on your base plates.
Posted on Apr 29, 2010
How do I install a moen mason towel bar?
Do the tips come off? Is it possible that the bar slides through the brackets? Most high end hardware has very small Allen screws to mount it. If not, go to Moen website for instructions or a phone number
Mar 24, 2012 | Moen 24 In. Towel Bar...
What is the distance from center of metal mounting bracket to center of other bracket for 24 inch ceramic Glacier bay towel rack
Put the towel rack together setting on a table and measure the distance between the two mounts.
make sure you know where the mounting bracket fits into the ceramic peace's.
Feb 03, 2011 | Home
The towel bar keeps coming off the brackets. How do I get this corrected?
Hi. Are the brackets (mounting posts) the correct distance apart? For a 24" rail, they should be 26.22" apart (outside to outside). If they are not then they probably need to be moved so that they are.
If they are correctly spaced, are the "notches" in the mounting posts facing downwards? If not, make this so.
If the notches are facing downwards, are the screws tight enough? If, not, tighten screws.
Hope this helps. Regards, Myles
Dec 31, 2010 | Moen 24 In. Towel Bar...
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
How can I attach a ceramic towel bar inside a tub surround without drilling through the surround? I was thinking about a good water proof glue. Any suggestions??
You could use a good water proof glue but that would only work for a short while. What kind of material is the surrounding made of? Ceramic towel bars are normally set in ceramic surroundings. If you really must have this towel bar you may have to cut two squares out of the surrounding and put in two ceramic tiles, that way you can put ceramic on ceramic.
Oct 04, 2010 | Moen 24 In. Towel Bar...
How do I securely mount a towel bar on a mirror?
My husband is a plumber. He says it's illegal to mount a towel bar on a mirror. People who do it illegally drill a hole thru it with a diamond drill bit. There has to be studs behind the mirror also.
Dec 30, 2009 | Moen Monticello Single-Handle Kitchen...
My door knocker was dropped and the knocker broke off. I cannot even it back together,
If you're looking for Baldwin, they're here.
If you're interested in repairing it, try getting some pc7 epoxy from your local hardware store. (see here) It's pretty amazing stuff. I use it to repair bronze scupltures. Give it 24 hours before you try knocking on it. Still, that's pretty hard use, and it there's any way to drill a pin into it that might help the repair.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 05, 2009 | Baldwin 0014.003 "S" Door Knocker,...
How do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Jul 17, 2009 | Moen 24 In. Towel Bar...
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Baldwin 3503 - Edgewater Tissue Holder Logo
77 people viewed this question
Top Baldwin Home Experts
Donni Steen
Tom Chichester
Are you a Baldwin Home Expert? Answer questions, earn points and help others
