Question about Microsoft Windows XP Home Edition
Print jobs don't get into a queue when print server is offline
I have an old Sony VAIO (running Win XP) that I am using a print server. The VAIO is connected to a HP PSC. The VAIO is on a wireless network along with two other laptops. One laptop is running Win XP and the other is running Vista. Everything was working fine as far as printing went until I reinstalled the OS on the Win XP machine (same OS). Previously the VAIO would go offline due to hibernation and so if I tried to print something from the XP machine, it would get in the queue and get printed when I turned the VAIO on. Now the print jobs are not getting in a queue when the VAIO is offline. I don't know what I did right before and so I don't know how to remedy the problem. Help!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
You must repair sharing to your all network,if not work you must check cable Lan connection try this.good luck
Posted on Apr 27, 2010
I have a x64 Win 2008 print server that I share print queues . All my clients are x86 Win 7 and XP x86. I was told that I had to change name of driiver for it to work, why and how do I do that.
Logon to the print-server, and change the name of the "shared" resource.
If that does not work, change the name of the print-server (if you understand what effect that will have!).
Jun 14, 2011 | Office Equipment & Supplies
I've got a document to print and when I click print it tells me (in the jobs queue) it is idle. This has only happened within the last few weeks. How can this be solved?
Power Cycle the printer sometimes resolved a problem like this.
Go to printer properties
right click and choose see whats printing for vista and win7 and click open for windows xp
pop up window will open then click on printer and cancel all documents
this will clean documents stuck on queue
go to start and click search for win7 and vista or click run for win xp
type services.msc
pop up window will open then look for print spooler
click restart on the spooler then it will restart only the print spooler
try printing again
Issue
The solutions in this document address the issue of print jobs getting stuck in the print queue
A log of print jobs waiting to print
. The following symptoms might also accompany this issue, and this document does address these other symptoms:
Printer won't print
Printer is Offline
No response from product
Check the print driver and the port
If you ever installed more than one HP product on the computer, the product might not be the default printer, or the wrong print driver might have been configured. Follow these steps to check the print driver configuration.
1.
On the Windows taskbar, click Start ( ), click Control Panel , and then double-click Printers and Faxes . The Printers and Faxes folder opens.
2.
Look for a black checkmark ( ) next to the product icon. This checkmark indicates which product is the default printer.
Figure 14: Example of default printer icon
Illustration of the default printer icon in Windows XP
If the wrong product is the default , right-click the icon for the correct product, and then click Set as Default Printer .
If the correct product is the default , continue to the next step.
3.
Right-click the icon for your product ( ), and then click Properties . The printer Properties window opens.
4.
Click the Ports tab.
5.
Look for your product under the Description column, and then view the Ports column to the left.
6.
Select your connection type to determine which port you should use
Mar 27, 2011 | Office Equipment & Supplies
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
Printer offline flashing light will not delete job
An offline condition can be caused by using third party ink or refilled cartridges.
To delete a print job that does not release the spooler, look at the bottom right of your screen. You should see a small printer icon. Double click on that icon to open the print queue Highlight the failing print job and then delete it.
Don
Dec 09, 2009 | HP Deskjet D1455 InkJet Printer
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Jun 19, 2009 | Office Equipment & Supplies
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
Cannot delete print jobs in queue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
This will clear out your print queue without having to restart. Good luck!!
Aug 22, 2008 | Lexmark Office Equipment & Supplies
Microsoft Windows XP Home Edition Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
