Question about KitchenAid Dishwashers
Kitchenaid dishwasher on the fritz, 5 yrs old pd $865.00
Kitchenaid KUDU02FRSS
During a regular cycle, the "NORMAL" and "CANCEL" buttons started flashing continuously, dishwasher will not operate at all. Turned power off overnite and when I turned it back on light blinks again??? Can I fix this myself? (Mechanical skills well above normal)
    President:
  • 949 Answers
The part you need is the console, what happens is moisture gets into the 'keypad' and causes corrosion shorting out the trails. The keypad is not a serviceable part it comes complete with the console which is not too hard to replace. I can help you with that if you want.
The part number you need is 8574148, it also has substitute number of W10083998
You can try calling Kitchen Aid to obtain the part or look in the yellow pages in your area for an appliance parts dealer. If it were me I would try KitchenAid first you never know they may cut you a break since you are a loyal customer...... if you know what I mean....
Posted on Apr 25, 2010
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Normal cycle never completes. Have to CANCEL to
check the temperature is reached the setting temperature,
or replaced the control board
Jun 04, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
254 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
