Washing machine is not going through whole cycle It is not draining or spinning and clothes smell stale
  • 64 Answers
Inspect drain hose for kinks or cloged up
Test the lid switch some models lid switch must be closed
Check water pump may be stoped up or not pumping
Check hose from tub to pump for blockage sometimes a sock or something will get in hose.
Check belts & pulleys if has any
Good luck
Posted on Apr 24, 2010
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
My baumatic washing machine is less that 9 months old and smells stale. I have tried doing a wash cycle with just washing liquid in and a cycle with bicarb of soda but with no sucees. any ideas? my wasking...
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. The bit about checking the motor is near the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Apr 09, 2011 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
Apr 26, 2010 | GE WBVH6240F Front Load Washer
Washer will drain but not spin out clothes
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 01, 2009 | GE WBSR3140DW Top Load Washer
My washing machine smells stale! If clothes are left in overnight they go smelly too.YUK!
your drain has lint stuck in it ,when the washers done the spin cycle the lint is still there and starts to smell when its done,remove drain hose and remove lint
Jul 07, 2008 | Hotpoint Washing Machines
Washing Machine Problem
if this is a sears or roper or whirlpool unit then check the direct drive coupling, if it sound like it should be spinning but doesn't
May 17, 2008 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
