Question about Scotts Company Scott'S& Lawn Pro Spreader 3 Pack
Scotts speedy green 3000, wont dial the setting
Only used a couple times, tried to find 4.5 turned it to one end - never saw any number but 1 end up in the center of the red window - now jambed wont turn back at all - is there a release mechanism?
  • 63 Answers
SOURCE: What is the setting for spreading 4 lbs per 100 sg
6 or 7
Posted on Jul 25, 2010
SOURCE: lost manual
I have a Scotts speedy green 3000. Got it $5 used. I just called Scotts, and they are sending me a manual. But, they told me how to calibrate it. First, you need to know if you have the same "version" as I do. Apparently they made the same model more than one way. I'm told I have a newer one. The way the Scotts rep differentiated was by the wheels. I have all black wheels with orange hubcaps. Older models have orange wheels. If you have the model I have, then do this to calibrate the spreader:
1. On the black slide that comes up when the handle is pulled to open the spreader and releasing product you will find a curved line about 1/2 and inch from the top.
2. Set the spreader to a setting of 2 on the handle.
3. When you pull the lever as if you were releasing product, the indented black line should line up with the curved part of the green hopper at the top of the opening.
4. If it does not align, then you need to adjust the cable that run from the handle down to the hopper door. This is done using pliers of wrench by turning the square nut at the bottom of the cable. It's trial and error at this point.
Mine was off by 30%.
Good luck
Posted on Aug 02, 2010
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
jyackle5
  • 8197 Answers
SOURCE: The product I want to
May I ask what product you are using so I can help you better
Posted on Feb 20, 2011
  • 65 Answers
SOURCE: I have a Scotts 76121
You can use the recommended settings for the SpeedyGreen 1000!
Hilary @Scotts
Posted on Aug 11, 2011
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
I have an older rotary scotts pro turf spreader and dont know what setting to put it on for fertilizer because the settings are letters not numbers how do i know what setting to put it on?
try this:
After doing a search I found this:
From Lesco website
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
_________________________
I was married by a judge. I should have asked for a jury.
-- Groucho Marx
Oct 20, 2010 | Scotts Company Garden
Have Scotts Edgeguard DLX. The fertilizer is from Intermountain Farmsers- The option for the Scotts brand is Scotts Speady Green. They give three options the 1000,2000 and 3000. Which option is teh...
I realize this is an older question but in case anyone has a similar question The Scotts Edgeguard DLX equivalent would be the Speedy Green 3000 suggested setting.
Oct 11, 2010 | Scotts Company Scotts Lawns Edgeguard...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Lost manual
Good luck
Apr 19, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts Company Scott'S& Lawn Pro Spreader 3 Pack Logo
116 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
