Question about Toshiba Satellite A135-S2276 Notebook
Hard disk problem
I m having 200gb sata of seagate
when i fresh installed my hard with xp sp2 its well working but after some time my every drives showing free space 1 to 3 gb less then the capacity it has(when i open the drive the drive it has nothing and also i try to format it but windows shows unable to format) please suggest me a wat to do ?
is my hard disk having a bad sectors thats why it is showing the problem
Try to load win98,then after the finishing the installation then Load winXP again the tell me the resuits.I'm waiting.
Posted on Mar 23, 2008
  • 655 Answers
Hmmm try to make SATA disabled from your BIOS setup. Because windows XP SP2 don't have any SATA driver, its came up with only IDE.
Try to disable your SATA it will fix your problem.
Thanks
Iqbal
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
No hard disk found......
You must first press f6 to load the SATA drivers for the hard drive before you go forward with the install.
Good Luck,
NOLA Tech
Feb 06, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Jan 17, 2009 | Biostar K8VGA-M Motherboard
Only 100gb of my 200gb hardrive are showing
Welcome to the wonderful world of windows disk size limitations.
What you are running into is the Windows 137GB Capacity Barrier AKA the 48-bit Logical Block Addressing Support for ATA (IDE), Serial ATA or ATAPI disc drives.
In English this means windows will only “acknowledge” between 127 and 137 Gig of a disk drive without some updates.
In most cases after he latest Service Packs are installed, any additional gigabytes will show up as unallocated space on the drive and you can create a second partition with the Windows disk management tools. Unfortunately this will mean that you have 2 partitions on the drive (if you placed your os on the drive or partitioned it before the updates were installed.).
If this is a secondary drive (in other words your OS is on a different disk drive), install all of the system updates first, you should then be able to format the entire drive as one partition.
Dec 20, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
New Hard drive xp install
If your hard drive is SATA and your windows disk does not have SATA drivers on it it will not find the hard drive this is your problem
http://driverpacks.net/DriverPacks/
Go to the above site and download "driverpack mass storage" and slipstream into your windows CD.
I have done this with one windows install disk that could not find disk then it worked perfectly
Nov 05, 2008 | Abit KT7-RAID Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk stops copying
sir,
first you scan pendrive with anti virus Soft ware why mens i think virus probalm your pendrive ok check pendrive witch company pendrive sir give me details full ok have a nice day by sir
Mar 14, 2008 | Computers & Internet
Maxtor Can't Touch
I understand the problem you are going through and it is due to the fact that win xp sp2 install an NTFS filesytem on its hard drive and this file system was designed to be secure in a way that you don't remove disk drive or add disk drives just like that.Now the best solution would be to just reinstall you xp machine with sp2 with the hard drive already in the case.In this way xp will be able to recognize it as one of its own drives and now you will have access to it.
Mar 13, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
