Question about D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N DIR-655 Wireless Router doing backup to a usb device local to pc works perfectly every time, but same USB device on router, after several gig errors out with "delayed write failed"
    President:
  • 1,768 Answers
This seem to me to be
the USB device that is being used is the issue.
1. firmware update may be required for the Router.
2.The error is related to the USB device.
3. Check the faqs for this router for further reference.
4. data progress may be halted due to the connection procedure used.
Posted on Apr 24, 2010
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Change time setting
change the time zone under the router and set the time manually and disable system or internet time inside
Jan 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
How do i add the printer the dlink dir 628 router
The DIR-628 does support a USB printer. You need to download the appropriate shareport version from dlink http://www.dlink.ca/products/?pid=DIR-628&tab=3.firmware
If the printer drivers are already installed on your PC you should be ready to go.
Sep 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DIR-655 Connection Support
Don't worry about it, The router is backward compatible to B,G and N only. the Router that your is wireless extreme N. Some of the A, D is not been supported by the router that means that we are on a new generation, there some older router can support the A,D.
Jun 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Jun 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
