Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I want to change my wep key How do I do this?
  • 2,263 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Apr 24, 2010
We are trying to sign on to our home network but the WEP key, after entering, keeps saying settings are invalid. What exactly is the WEP key? What do we need to do?
Are you trying to connect to your internet connection for wireless? If it is, the WEP key is the password that you set up for your wireless device so that devices that can see the your wireless network will be able to connect by entering the right WEP key. If you didnt change the WEP key of your modem or router, then the default WEP key will be found at the back of your device, but if you had changed it before then, that's the WEP key that you need to enter.
Sep 05, 2011 | Nintendo DSi Black Console
Cant find wep key
You will need to access the router (via its local web address using a suitable web browser) Once you have provided the login information, surf to the wireless security section and either document the WEP key (if not encrypted) or change it. Understand that changing the WEP key will invalidate any else's access, so be sure to share the change. The WEP key may have to be done in HEX, meaning that it must be done with the numerals 0-9 and ONLY the letters A-F. The ket must also be a specific length, usually 13 or 26 characters depending on the requirements of the router.
Aug 11, 2011 | NetGear WGR614 Wireless Router
I need to know what the wep key is
Jun 10, 2011 | Linksys WRT120N Router
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
Keep having to enter the wep key to start ps3 then it times out saying the key is incorrect ? Recently changed from AOL to BT and console was working fine but now no service
Can I just ask, are you entering your AOL WEP key or your new BT WEP key? Just in case you didnt know your BT router will have its WEP key on a sticker on the back of the router. You need to go into network settings --> internet settings and change the WEP key that is registered to the system. It should then connect with no problem.
Hope this helps.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
We are looking for a Network Key on a 2 wire 638 sometimes referred to as WEP key or WPA key
The 2-Wire comes with built-in Wireless key, WEP-10 digit key, which is located at the bottom of the product, near the bar code label. However, you can also change the default WEP Wireless security key.
You can view the complete details to change the default Wireless key in the link posted below.
http://support.2wire.com/?page=view&article=60&text=wireless%20key&cat=&sort=
Jul 03, 2010 | Computers & Internet
I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Oct 28, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need help with my dynalink router i changed the ssid and made a wep key
If you changed your WEP encryption then you've changed your WEP key. 64 bit WEP encrytion uses a 10 charater hexadecimal key and 128 bit uses a 26 charter hex key. You can not switch between the 2 configurations and keep the same key.., although some wireless adapter utility programs will generate a new key for you from the same "passphrase". Most likely your key has changed which would give you that problem. If all else fails, set your router back to defaults (open).. and make sure everything connects... then apply your key and be sure all computers and devices use the same key
Feb 17, 2008 | Computers & Internet
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
110 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
