Question about Bosch Nexxt 500 Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
Our Bosch Nexxt 500 gas dryer takes a long time to dry on the permanent press very dry setting. Usually requiring two cycles before the clothes are dry. Doesn't seem to matter if the load is large or small (in fact, smaller loads tend to do worse). Regular/cotton extra dry setting works fine.
The washer is also a Bosch Nexxt 500, and seems to spin the clothes well. The dryer is a gas dryer. Lint catch is regularly cleaned, the vent is only 5 feet long with a single 90 degree turn where it exits the dryer. I replaced the flexible duct with a solid one (this helped a little, but there didn't seem to any big blockage in the old one). I replaced the moisture sensor on the dryer, but that made no difference. Dryer reports no error codes.
Any suggestions for things to look for?
Thanks!
  • jerrymr Apr 30, 2010
    Tried cleaning the moisture sensors with a wet rag, but it had no effect. Any other suggestions?
  • jerrymr Oct 07, 2010
    I wish. Nothing seems to make it dry in a single cycle on permanent press. As I said in my initial post, I even tried replacing the moisture sensor (the chrome strips cpldw48 mentions) with a new one, with no effect. I think there is just an inherent defect in these dryers. I would not buy this again. Sorry I don't have better news.
Did you ever figure this out? I have a new Bosch and can't get the clothes to dry.
Posted on Oct 07, 2010
    CBKS - see second comment under the main post.
    Habit-Forming:
  • 133 Answers
If you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Posted on Apr 25, 2010
Why does my bosch dryer not drying my clothes
will need to check the fuse thermostats also before buying new heating element, the thermal cut off may be bad, the cycling switch, the hi-lo thermostat u can test the heating element with a multimeter for continuity etc?
Dec 18, 2014 | Bosch 500 Plus Series Nexxt Clothes Dryer...
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
The dryer doesn't heat up and dry the clothes. I checked the troubleshooting section and then cleaned the lint filter, which we do after every time we take dry clothes out, and then I made sure the exhaust...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 28, 2010 | Bosch Nexxt 500 Dryer
My bosch nexxt 500 series electric dryer is not heating up. what could be the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 05, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch Nexxt 500 Dryer takes way too long to dry!
check your flex vent hose on back of dryer are go out side your home an locate where the vent come out of your home an see if the air flowing out of your vent, if not you need to pull the dry out take the hose off of the dry an clean the lint out ok, an send me the money you find in the vent ok
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Why does dryer stop when the clothing is still damp?
I`m assuming you have not received any error code from the dryer since you didn`t mention that, but would I be correct ?
Have you tried both timed dry and auto dry settings ? If this happening in both setting`s it will help narrow down what to look for.
Are the cloth`s typically spun out really well by the washer ( and is it a Bosch Nexxt as well ) before entering the dryer ?
I will watch for your response in this post and hopefully I`ll be able to help find an acceptable solution for you.
macmarkus :)
Apr 08, 2010 | Bosch Nexxt 500 Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
713 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
