Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Spray arm not turning
Spray arms are not turning in dishwasher. The bottom will fill up with water and their is steam but the arms are still in the same place. I took everything out down to the chopper assembly and nothing was clogged. I ran the diagnostic test and nothing was noted.
Is the blade in the chopper assembly suppose to turn by hand? If, mine does not. THANKS in advance :)
  • KitchenAid Master
  • 43,501 Answers
Check out this tip it will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 25, 2010
Dishwasher not cleaning dishes; water not coming out of top spray arm
You are right to go to the inlet filters. If they are clogged you would lose pressure, but not that much...The pressure pump is probably not outputting any longer. Locate it and see if it is moving freely.
Jan 14, 2013 | Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
The top spray arm is not turning as best i can tell. bottom one is.. frigidaire model # fdb1050rec2. please help! thank you
If your dishwasher does not fill up with the correct amount of water the top spray arm will not get the water pressure it should.
The water level should be just under the heating element.
Aug 03, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
Spray arms not turning in dishwasher
Water pressure makes the arms move, so your pump must be defective
Aug 28, 2017 | Dishwashers
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Bottom spray arms will not turn
SOUNDS LIKE YOU MAY NEED A NEW SPRAY MOTOR.
Jan 27, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Spray arms
Sounds like the circulating pump is faulty or the spray arms hav become partially clogged. Loss of available water will stop the spray arm motion.
Feb 05, 2007 | Kenmore 16872 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
126 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
