Question about PfaFF Creative 7570
Tension has thread caught in it.
Inside the cover of the machine where the tension disks are 'I have thread caught and cannot find out how to get the cover off so I can remove this thread from the tension.
    New Friend:
  • 10 Answers
Hope this helps. In the order I would recommend:
  1. "Floss" the tension disks - this is nothing more than running a heavy thread (12 weight or upholstery) through the thread path, grasping the thread at the spool and the end that is through the needle and "flossing" just like you would your teeth - slide the thread back and forth through the disks/thread path. This will often-times pull through whatever is stuck!
  2. If the thread is more deeply tangled than "flossing" will fix, you CAN remove the top of the machine to better see it. I would, however, recommend you take the machine to a Pfaff-trained tech if this is the case - things that can be damaged if you're not trained on the machine. However, if you're wanting to give it a try (the thread may be easily visible and easy to get to):
    • Remove the stitch lid - there are little metal clips at the base of the lid that you can push outwards to remove the lid - can't get the top off without removing lid.
    • In the well of the machine top are a few screws (2 if I'm remembering correctly). The screws are star-shaped as opposed to Phillips or Flat - special screwdriver is required. Just make sure you don't remove the screw that's holding the bobbin-winding mechanism on.
    • Once the screws are loosened, you'll have to maneuver the top out of it's position - this requires a little wiggling but is not impossible (just impossible to describe how to wiggle it!!)
    • Turn machine OFF and UNPLUG it. Too many electrical connection points you will be working around to take a chance!
    • VERY CAREFULLY... turn the handwheel towards you (never turn backwards) until you are able to view the entire race/thread path. If you can EASILY remove the stuck thread, go ahead and do it. If you have to do too much pulling and tugging, be VERY careful - if the thread is wrapped around the check spring, you may bend/break it.
Again - hope this helps!
Happy sewing,
Kim
Posted on May 04, 2008
The tension on my Juki TL98E will not stay set. the top thread is really loose underneath, but if I tighten the top tension, it skipps stitches and the lower thread is not caught in the stitch.
Your top tension may actually be too tight! Try loosening it a bit instead. And check that the bobbin is correctly threaded and your needle in good condition.
Nov 25, 2015 | Juki Sewing Machines
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
Oct 02, 2015 | PfaFF Sewing Machines
What should the tension be set on
Replace your needle
Re thread your sewing machine
Remove lint or thread caught in the needle or bobbin tension disks
Refer to your instruction manual if you don't know where these disks are located.
Jan 31, 2015 | Sewing Machines
Still having with husquvarna designer I sewing machine. Tried new needles, changed stabilizer, tightened tension and loosed tension and still it is wrapping around needle plate and bunching underneath
Check bobbin case for loose threads in spring area that could be causing bobbin not to hold enough tension on bobbin thread. You can check bobbin case tension by using your needle plate. Holding bobbin case in your hand, insert a bobbin and thread it through the spring as usual. On the end of the bobbin thread, tie your needle plate to the thread. Hold case in your hand side ways so that thread travels downward with needle plate and thread trails downward across the case. The case should be perpendicular to the table top or floor. The weight of the needle plate should be so that the thread does not travel down unless the bobbin case is shaken slightly. The thread should then travel down slowly but stop once you hold case steady. If this is ok, check top tension. Turn on the machine. Lower the presser foot. With needle threaded, pull the thread the needle. You should feel some resistance. If there is none. Raise the presser foot and brush out any loose threads that might be caught in the upper tension disks. Many times, loose threads can get caught here that will keep disks from closing completely.
Hope this helps. Good luck.
Oct 30, 2014 | Husqvarna Designer I
How do I adjust the thread tension on a durkopp adler 267
I'm not familiar with this machine, but there is usually some kind of provision to adjust the upper thread tension. If you have tried that and the tension is still loose, there is a good possibility that your top thread is not "seating" correctly--the thread on any machine goes through two disks, which apply the upper thread tension, and the thread may not be between the tension disks at all, or the thread is just on the outside rim.
First, for ALL MACHINES of any make, going back to 1859 when they were first invented, you MUST MUST MUST thread with the presser foot UP--and I did not know that for years! The reason is the tension disks the thread has to go through to apply tension are only spread when the presser foot up is UP. That allows the thread to "seat" inside the disks so that the machine can apply tension. Once the foot goes down, the disks come together to grab the thread.
If you have done that and it is still loose, there may be something--like lint or broken threads--in the center of the tension disks, preventing the thread from seating all the way. Take a piece of UNWAXED ONLY dental floss, and with the presser foot up, thread the machine, then gently "saw" the floss back the forth to dislodge whatever is inside those disks.
Sep 13, 2014 | Sewing Machines
Why is my bobbin thread tangling and binding up under the plate?
Check tension levels of both upper tension unit and bobbin case.
With machine threaded, pull the bobbin thread. There should be some tension/resistence. Lower the presser foot. Pull on the top thread. Again you should feel some tension/resistence. If you don't feel any, raise presser foot and test upper thread again. If no difference, it is an issue with the upper tension disks. Brush out any loose threads that might have gotten caught in the upper tension disks which is causing the disks not to close. If there is no difference with presser foot up or down and no threads in tension unit, the tension unit will probably need to be replaced. You should have the machine serviced at the local authorized husqvarna viking dealer. You can find the nearest dealer at the husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 27, 2014 | Husqvarna Sewing Machines
Husquvarna tension disc diamond deluxe how do i know if their loose
When the machine is threaded, raise the presser foot. The tension disks will release when the presser foot is up. If the thread is hard to pull with the pressed foot down it should be working. If not, there might be lint or something caught between the tension disks.
Nov 05, 2013 | Husqvarna Sewing Machines
The top stitch is fine but underneath the thread is all balled up what might be the problem
When the thread is bunched up underneath, the problem is often in the top tension. The top thread is pulled through to the bottom but because there is no tension, it isn't pulled back up correctly, creating large loops underneath.
Try making sure that the thread is lying correctly between the tension disks (you can just see them inside the machine on the downward thread path). Lifting the presser foot lever (behind the machine) opens up the disks and lets the thread slide between them more easily. They will close again when you put the presser foot down to sew. Make sure you always thread the machine with the presser foot lever up and tension disks open to avoid this problem in future.
If the thread is running correctly between the tension disks, just check that you that there's no fluff caught in there, holding them open. Give it a blow, or run a folded pice of fabric through there.
Nov 26, 2010 | Singer 2259 Sewing Machine
Need online manual
If you are having problems with the thread on the underside of the fabric, that is usually the upper tension. Check to make sure that it is threaded correctly. If so, make sure that the thread is inside the tension disc and that there are no pieces of thread caught in the tension. If it is threaded and there are no thread caught up in the tension assembly, adjust your tension dial to a slightly higher number. Do this until you get a good stitch.
Feb 09, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
319 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
