Question about Lexmark X3550 All-In-One Printer
Screen says clear carrier jam then press (checkmark) but nothing is blocked...when i press the checkmark the slide slams the side of printer...then the same thing comes back on screen
  • 4,041 Answers
Hello there This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
I keep getting an error message that says clear carrier jam and then press the checkmark. However, there is no jam that I can see. Whenever I open the top of the printer the cartridges just remain stuck to...
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
Dec 22, 2009 | Dell 926 All-In-One InkJet Printer
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
The ink carrier has a clear carrier jam message...
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
2. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jam
hi,
Follow the wizard on the following website , to help you to pinpoint the problem
http://tinyurl.com/3nh59x
Thanks
Proton
Oct 02, 2008 | Dell 924 All-in-One InkJet Printer
The printer carrier slams to the right, when i try to print, and the readout says , carrier stall
A gear in the carrier is stripped or has fallen out of place.I've had this happen on several ink printers where the in-users jammed the printer and then forced/pulled the print head. You can often take these apart and get them serviceable in the short term. But once they break they don't last. I don't know what model printer you have specifically and I've never bought the parts for replacment, but in most cases it isn't worth the effort.
Jul 30, 2008 | Lexmark Office Equipment & Supplies
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X3550 All-In-One Printer Logo
260 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
