Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
THE ROLLER WON'T GO AROUND. THE EXTRA ATTACHMENT WORK WELL, BUT THE ROLLER STOPPED GOING AROUND.
  • 438 Answers
HI There,
This is definitely a problem with your belts. This Hoover Windtunnel Self-Propelled models has a poorly designed belt system that frequently goes bad. Most customers will have to replace the belt once every 8-12 months, some even more frequently than that.
There are 2 belts on this machine, and it's recommended that you replace both belts at the same time. If you just replace one of the belts, this will cause the other belt to go bad quicker.
If you don't already have the replacement belts, here are links to these belts through us:
Hoover WindTunnel Self Propelled Belt Set (38528-034 & 38528-035)
Here's a helpful video that we've recorded that shows you step by step on how to replace these belts, as well as how to do the basic maintenance on the roller brush to prolong the life of the belts as long as possible.
How To Replace the belts on a Hoover Windtunnel Self-Propelled:
Please be sure to rate this repair helpful, or leave feedback if this video helped you fix the problem. If you're still having problems, please just use the comment field on the repair page and leave a little more specific information on what happened when you inspected the belts, and I'll be more then happy to do some further more advanced diagnosing for you.
By rating the repairs helpful, and leaving feedback, this ensures that Fixya experts continue to leave free repair solutions rather then just leaving premium answers, or repairs that customers pay to have answered. This is also really appreciated.
Chris Jones
GoVacuum.com
Posted on Apr 28, 2010
  • shirley chao Jan 31, 2011
    Thank you for the video showing how to replace the belts. I am a visual person, so this is most helpful. Also, I only replaced the flat belt. But with your recommendation, I will go out and purchase the v belt to replace also. Thanks again.
  • Andre fraissinet Aug 10, 2013
    Yes as Simone else posted if you replace both belts it should be good to go
Replacing the belts is pretty straightforward, but the new one is too loose also, like the worn out one, and the brush still won't move. I am coming to despise this unit.
Posted on Apr 30, 2010
After checking a myriad of answers to this particular question, I suggest you query "new actuator arm for self-propelled Hoover Wind Tunnel" it's part number 43143046. There's a very good video; hopet I'm allowed to post the link here. https://youtu.be/K722IsUxjYM
When new belts don't fix the problem of the brush no longer turning, it's often the actuator arm or the cable that connects to it.
One place I checked said that this problem occurs when machine picked up by propel handle it rips the nut and bolt out of idler arm causing it not to work.
Posted on Nov 07, 2015
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I ran the vacuum over throw rugs and the brush roller just stopped. I can't get the roller to work now... it won't even spin and the "brush" feature is in the ON position.
You've got a broken belt. Most Hoover Vacuums have a spare belt attached to the vacuum itself. Replacement is fairly easy and usually won't require tools. To replace your belt:
  1. Unplug the vacuum
  2. Locate clips on bottom of vacuum-Hoover uses clips that can be opened by hand.
  3. Lift up the plate that encloses the rollers
  4. Remove broken belt
  5. Remove roller from it's compartment
  6. Install replacement belt (hooking it around the motor and roller, using the roller for leverage to stretch out the belt until you have the roller in it's compartment.
  7. Replace cover
  8. Put clips back in place.
Mar 21, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
May 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
1,824 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
