Question about Casio Marine Gear AMW320D9EV Wrist Watch
The black plastic ring, w/ white markings (bezel ?), that goes on the metal (dial) which moves around, fell off. Is this part avail., and if so, for how much ?
  • trawitzki1 Apr 26, 2010
    I need the bezel for a casio amw320d-9ev. Please reply if avail. and for how much. Thanks
    Problem Solver:
  • 5 Answers
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Posted on Apr 25, 2010
How do I use the moveable outer numbered ring on the t49825dh?
The numbered bezel can be used by divers to measure elapsed time on their oxygen supply. Place the zero where the minute hand is now and you'll know when 20 or 30 minutes have passed when the minute hand reaches bezel number 20 or 30.
In the same way, you can use the bezel to tell when 30 minutes have passed on your parking meter if you simply put the 0 on the minute hand when you leave the car. When the minute hand reaches the 30 mark, a half hour will have passed.
Typically, the bezel only turns counterclockwise to keep the wearer from bumping and changing the elapsed time number. On some less expensive watches, the numbered bezel does not turn and is decorative only.
Oct 23, 2014 | Timex Tiex en T49825DH Expedition Military...
How do you change battery on E Howard wrist watch, how does bach come off?
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
artcoadm@pacific.net.hk
Model number on my module is AR600 WWVB (37.5mm)
Nov 18, 2010 | La Crosse Technology E. Howard Ambassador...
I have a 7 year old Raymond Weil Women's Parsifal watch, stainless steel, bracelet, rectangular face. The outer face in stainless steel, that has four roman numerals on it, has somehow fallen off, or...
If you are talking about the bezel, which is the bit on the outside of the watch, you should contact the Raymond Weil repair centre SWICO. They repaired my Othello when half the bezel fell off. They had it back to me in no time! Their details are on the Raymond Weil website:
http://www.raymondweiluk.co.uk/t-faq.aspx
Good luck
May 11, 2010 | Raymond Weil Watches Tradition 18K Gold...
I have an omega speedmaster and the bezel fell off I want to r
Any good quality SUPER GLUE will do the job. Apply to the case only and push the ring straight away onto it. Make it precise first time, as there will be no aligning possible afterwards. Rate me, please.
Apr 08, 2010 | Rolex Daytona 116528 Wrist Watch
A metal jewel fell off of the watch face and is loose on the dial
I suggest you take it to a watch shop and ask them to repair it for you.
It can be more difficult than it appears to remove and replace backs particularly.
Feb 25, 2010 | Watches
My Times ReeFGear 50832 watch accidentally fell on the ground while wearing it and the outer ring of the watch is detached from the dial. Now since the plastic hook of the ring that attaches the ring to...
I suggest that you go to the Timex web site "timex.com" and click on "contact us" and you will see some addresses, phone numbers and email blank.
If you contact them, they should be able to help you.
Feb 16, 2010 | Timex 50832 Wrist Watch
The outer dial free spins instead of clicks what is wrong with it
I think you are referring to the bezel around the crystal (glass). There is a spring under the bezel and it has broken. It can be replaced.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Fossil Metal Chronograph Blue Dial...
How to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
Sep 18, 2009 | Watches
Hour-hand fell off clock
Plastic clock glasses are fitted on clocks in two different ways:
1) Clip-on plastic glass;
Check carefully all around the plastic glass and find where the clips are positioned. Insert the screwdriver between the glass and clock bezel and use the lever action to unclip it. Do the same to all clips following one by one till the glass come loose.
2) Glued plastic glasses;
Do exactly the same as described above, just this time go bit by bit all around the glass till it come loose.
NOTE: In both cases the plastic glass can crack if you are not expierenced in such an action! Start with ease and do not force that plastic glass too hard.
Rate me, please.
Mar 14, 2009 | Timex Watches
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
Casio Marine Gear AMW320D9EV Wrist Watch Logo
155 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
