Question about Dell Inspiron 1501 Notebook
Error 3600:0749 battery adapter is plug in but not charging.what's the problem for this?
    Scholar:
  • 62 Answers
Most Dell adapters have an LED on them when they are plugged in. If it is off, replace the adapter. If it is on, try running the laptop on AC, without the battery. If this works, then the motherboard is probably OK. If the only problem is that the battery won't charge it is probably a bad battery.
Posted on Apr 26, 2010
3 Suggested Answers
  • 3940 Answers
SOURCE: error code 3600:0749 battery will not charge
If the system is only 6 months old, then it should be under warranty (Minimum warranty at Dell is 1 year) So contact technical support and let them assist you in finding the failure (800 624 9896 USA)
Posted on Oct 02, 2009
Testimonial: "thank you for the advise. i only hope that dell will do more than send me another adapter seeing that many are saying that the adapter is not the prob"
  • 76 Answers
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Posted on Oct 03, 2009
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
My laptop was plugged in but no battery. accidentally switched off the cable from the adapter and the laptop shut down. I turned back cable from the adapter and I could not turn on the laptop. I put the...
take your battery out and keep the ac adapter out aswell hold power for 15-20 secs replace battery and ac adapter then try powering on if not message back i got another idea ok
Jun 02, 2011 | Computers & Internet
Itjust won't charge i need the mains plug in
Check the voltage at the battery terminals in the PC and while the charger is plugged check to see the incremental increase of voltage on the battery. If so the battery is faulty as it fails to charge. If not there are errors in the charging circuit in the PC , if your adapter has been tested to work well.
Feb 05, 2011 | Computers & Internet
I have nokia 6120c charging shows but not store on battery even i changed new battery please help!
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
Feb 04, 2011 | Nokia 6120
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
The laptop does not charge the battery but the battery charges off the laptop (long life battery)
Could you again specify the problem. if i understand it correctly the laptop battery is not gettiing charged when the Ac adapter is plugged into the laptop. The secong part about the long battery life is not clear.
The battery may not get charged witht he AC adapter due to two reasons
1. A bad ac adapter
2. A bad battery
if the battery is more than 1 year old , it may have reached its end of life.
To confirm the same. Restart your computer and when you see the Dell logo before windows starts tap on the F2 key a couple of times.
You will enter system setup
Using the down arrow key go to the option battery info or battery health. check the status of the battery . Also check if the Ac adpater is listed there or not . If the battry reports an error it needs to be changed . If the Ac adapter is not detected then the Ac adapter needs to be changed.
Thanks for using Fixya
Proton
Apr 18, 2010 | Dell Latitude C400 Notebook
Bought a new ac charger for the laptop and tried to charge it up ,critical low battery error keeps coming up and computer switches off
replace battery, as long you adapter plug in indicator work charging also work so only battery not accept charging.
Apr 04, 2010 | Lenovo ThinkPad R61 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Jul 26, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
559 people viewed this question
Alun Cox
