Question about Polaroid TLA-04011C 40 in. LCD TV
Removed cord from back and replaced it now it will not come on
We removed the cord from the back to move the tv across the room ..pluged it back in 5 minutes later and it will not come on
    President:
  • 196 Answers
Check swith near ac cord. maybe you push accidentaly
Posted on Apr 24, 2010
Hi i have the samesung ln26b360 lcd tv and for some reason when i went off to college like the 3rd day i had my new tv i had to unplus it to move it to the other side of the room well i moved it plugged it...
The tv power supply board is likely the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 30, 2010 | Samsung LN26B360 26 in. LCD TV
I unplugged tv to move it across the room now it wont turn back on??
POE:
  1. Connect tv directly to socket without any powerboards and make sure the power cord is properly inserted (if it works than any powerboard you have been using is probably faulty)
  2. Try a different power cord
  3. See if socket is dead using another appliance. If another appliance works then the Tv is probably damaged (refer to warranty if applicable)
  4. if other appliances don't work in that socket check your fuse box.
  5. If fuse box is fine then try a different socket (if it works you may need to get an experienced person to fix the socket your trying to plug the tv into)
Dec 20, 2010 | Televison & Video
I have this Samsung but theres a wash and dryer behind the tv in another room. theres a annoying buzzing sound and theres lines going across the tv when the washer machine is on. what can I do to reduce...
hi,
you can try using a good quality surge strip on the tv. if that doesent do it you could try a different outlet on the other side of the room, or try using an outlet from a different room(long extension cord) if that doesent do it you may have to move the tv to another wall.
jm
Nov 15, 2010 | Samsung HP-T4254 42 in. Plasma Television
The TV Will Not Turn On
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Jan 24, 2009 | Panasonic CT-32SL13 32" TV
Where Is The Fuse Located In A Panasonic CT-32SL-23G ?
There are 4 screws across the top, one on each side on the bottom toward the front, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Snow Across the screen
just check the antenna wire or the coaxial cord
Oct 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV on getting switched on
There are 4 screws across the top, one on each side on the bottom, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Jun 28, 2008 | Panasonic CT-32SL13 32" TV
LG Plasma TV
first i would try unplugging it for about 5 minutes to reset the set. after that i would need more detail as to the problem is there sparkles in the screen is it a certain portion of the set any info you can give
Jul 03, 2007 | LG 42PX4DR 42 in. Plasma TV
Polaroid TLA-04011C 40 in. LCD TV Logo
144 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
