Question about Amana SXD524VW Side by Side Refrigerator
Refrig is at 60 while freezer is fine--What do I do???
Amana side by side 596SX25M/36538 (My model wasn't in the given list.)
The freezer is fine but the refrigerator is not cooling. Dial is set on 5 or 6 right now and the temp is around 60.
I've pulled it out and cleaned--nothing much there. I've taken the front botton panel off and cleaned there. I do have four cats so there was quite a buildup of hair there. I got it all out several hours ago now and there's no change in the temp in the refrig side.
I'm hearing (and have heard it running) and the sounds seem to be normal.
Any suggestions?
  • Amana Master
  • 43,501 Answers
Posted on Apr 25, 2010
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Amana Model SZD25NL is not cooling at all, neither
compresor fan working? if it is not you need to consider the compressor starter need to be replace
Dec 29, 2009 | Refrigerators
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABB2224DES Stainless Steel Bottom Refrigerator is warm however the freezer works fine. How do I solve this problem? I vacuumed the coil and renoved most of the dust accumulation. Is there a way...
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Sep 02, 2007 | Amana ABB2224DES Stainless Steel Bottom...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Amana SXD524VW Side by Side Refrigerator Logo
91 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
