Question about Microwave Ovens
Sharp Micro(R-1480) No Heat now after replacing bottom of 3 door switches,was working fine before.(Switch was replaced as a closed door did not activate a start.) All wires are hooked up properly.With bad switch it was heating with door slightly ajar - now new switch,all else works(table,lights,timer)- no heat. Thanks, Mark, Waukesha
  • ForwardOnWI Apr 24, 2010
    Thanks firesnake- I noticed that the heating noise (even though not heating now) is at least twice as loud..does that mean any certain component (rectifier too?). Thanks again!
    Thanks Firesnake for your insight!
    President:
  • Microwave Ovens Master
  • 2,923 Answers
Mark,
Based on your statement, I would think that the problem is the magnetron of your microwave.
You need to have a pro to check the first the capacitors, fuse, and resistors that might prevent the magnetron to work. If the components are good, then the problem is the magnetron and needs to be replaced.
Thank you and good luck!
Posted on Apr 24, 2010
  • Melvin Ramos
    Melvin Ramos Apr 24, 2010
    Mark,
    You are correct, rectifier might be the one causing the noise.
    Thank you!
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Replaced the 20amp fuse in my microwave. Clock and all lights work but oven will not heat
one or more of the door micro switches are open or shorted..the micro switches tell the unit the door is closed and safe to use.the micro switched are marked normally open or closed..take note when replaceing them..also their is a actuator lever that tells the switch to close or open..it is plastic and connected to the door latch..it can be broken off or bent from heat,,its plastic..make sure its in place and working the micro switch
Aug 15, 2014 | Microwave Ovens
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel will not turn on unless I lift gently on the door.
the door interlock switch needs adjusting or replacement
Mar 26, 2009 | Sharp R-1480 Microwave Oven
No power
That would probably be a bad secondary interlock (bottom door switch) or its mount.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 11, 2008 | Sharp R-1480 Microwave Oven
I'm having problems with the door switches on my R-1480
We have the R1480-series service manual for this model and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
Double-check your wiring against the "pictorial diagram".
The switches will have a "C" (common) terminal, and a "NO" (normally open) terminal, and some will have a "NC" (normally closed) terminal.
As long as those connections are the same and the voltage and current (amps) ratings are the same or higher, any number of switches will work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
It's easier to secure the switches with hot glue than to replace the latch heads, by the way.
Jun 11, 2008 | Sharp R-1480 Microwave Oven
Oven will not work unless I push on the door
It's probably a broken tab on the dooir switch mount or a screw holding the door switch mounts is loose.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can also order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Sharp R-1480 Microwave Oven
Microwave oven inoperative
check high voltage section, check magneatron, diodes, etc.
Nov 02, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
