Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lt 2000 17.5 hp i need a oil filter and air filter
  • 148 Answers
SOURCE: Craftsman II mowre oil capacity and filter type
Go to www.managemyhome.com and manual for your tractor. All you have to do is type in the model number without the period between the 917 and 254 i.e. 917254610.
Posted on May 19, 2009
  • 3 Answers
SOURCE: craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Posted on Jun 23, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for Craftsman LT 2000 42
Look under the "running boards" Sears(AYP) sometimes put them under there. If not, go to www3.sears.com, type in your 917.xxxxxx model number and the pictures will show you an exploded view of the belt configurations
Posted on Sep 14, 2009
My Craftsman LT 1000 21 hp 42" cut MN scratched out only thing readable is "conforms to 1998 safety standards" and it does not have an oil filter...can you tell me the model number?
go too SearsPartsDirect they can help you can ask a repair queston or anything if they cannot help try Parts Tree Repair Clinic
Mar 20, 2017 | Craftsman Garden
Losing power
I take it its a Briggs motor
It sounds like 2 possibilities
1 possible half sheared flywheel key causing out of time conditions
2 carb is dirty not due to your new gas filter but dirt through air inlet and needs to be taken off diassembled and cleaned (carb cleaner and determine all jets and small orfice holes are clean.
Aug 09, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 20 gal. 2 hp, twin cyl., model # 106.154781. What type oil does it take and I need air filters and a new drive belt.
Most aircompressors these days take non detergent 30 like an hd 30 gear oil , call sears they will have filters and belt
Aug 22, 2011 | Craftsman Air Tools & Compressors
I don't have an owners manual. I need a new oil filter for Craftsman LT 1000
You need the model number off the engine. With the model number and the brand you can go to the local lawn mower repair parts shop and get the filter for that engine. But if you would like to send me the complete model number and the brand of your engine I will look it up for you to get you the part number so you know what to look for when you go to get it.
Aug 12, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Do I need to mix oil with my gas for the lt 1000
Simple, it is seperate. There is no need for a mixture
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 15 HP Lawn tractor is spewing white smoke. When I removed the air filter, I noticed there was oil all over the inside of the air filter and at the bottom of the air filter. When I run the...
I could be caused by a couple things, the most common is overfilling with oil, running on too great of angle and flooding the valve stem area or really bad valve stem seals.
Jun 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
Oct 11, 2009 | Craftsman Garden
MTD TRACTOR FLIPPED UPSIDEDOWN; NOW IT DOESN'T START ???
Does the engine turn at all? If it does, the you probably need to replace your fuel filter, air filter, and spark plug.
On small engines, when they get turned over like that, oil tends to go places it shouldn't. Usually that means that your filters, and carburetor, and from there into your cylinder, fouling your spark plug.
Check those items, and replace any that have traces of oil in/on them.
Apr 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
1,005 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
