Question about Mtd 22" Yard Machine Push Mower
Have had this spring for my Dad before and he can not figure out how to put it on again and for some odd unknown reason I can not pull up the manual please help. Part # for this spring is 732-04280B. Please tell me where I can find this online so I can get this done.
  • 143 Answers
I don`t know what you are talking about but if you try www.superxpower.com and put in your machine and model you might find something. Stephen.
Posted on Apr 26, 2010
Pull cord on briggs & strtton wont retract back
If you don't know how you will need a manual, it is kind of tricky.
Remove the rope. Feed the spring from the outside of the housing and connect to the recoil housing. Turn the wheel using a 3/4 " rachet extension and the spring will feed ito the housing until the end of the spring connects to the ouside of the housing. Keep turning until the spring is tight, back off about 1/2 turn and feed the rope from the outside, be carful here, if the extecsion comes out the spring will uncoil and you get to start off all over again.
Apr 16, 2013 | Briggs & Stratton Garden
I did a really dumb thing... Kohler bypass shower doors, frameless. For some odd reason, the bottom piece fell off the inside door! I scraped off the left over silicon glue, got some more, and very...
I know it's is going to be a tedious process to remove,clean, and replace bottom piece but I think that is what you need to do. Sorry I don't have a easy fix for you. Good luck and thank you.
Jan 25, 2011 | Kohler Home
I was copying vhs tapes to dvd successfully and then it started saying disc unknown.cant figure it out
this issue calls for a little info from my brain
have you tried to reset the recorder if so is there firmware updates for the burner
have you changed the brand of dvd disks lately if so sometimes a different disk has issues for some odd reason i have run into this problem before
Jan 03, 2011 | GoVideo VR3845 DVD Recorder/VCR
Cant find book on the musical ferris wheel we put everything in storage now we cant find the book can you please help use it is importion to my son to get another book because his dad got it for him 3...
You can download the manual on the link below. If it does not come up with the model In the box on the top type in 15137 as the kit #
http://www.knex.com/model-instructions/?pc=15137
Good Luck and please rate 4 thumbs up for the free answer
Sep 28, 2010 | K'nex Toys
I can't put mt paslode finish nailer back together again
go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Jul 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Mtx ampnot working
Try disconnecting the power supply and ground completely and reconnecting it starting with the ground then power and then the remote lead- Ihad a kenwood that was picky like that and if you hooked it up in the wrong sequence it wouldnt go -but once i figured that out- i never had a problem with it again-till someone stole it-.haha good luck-why did you pull the fuse to bridge your amp?thats odd-any particular reason?
May 29, 2009 | Jl Audio E1200 Car Audio Amplifier
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Problem with a WindTunnel 2 Extra Reach Bagless Upright (U8351900)
My dad fixed it by putting the spring under the arm lever and the roller on the outside part of the belt than in the inside as I have been trying to do.. I did however put one part of the spring in the right area of the vacuum. In a hole on the bottom area of the inside. The spring that is bent in a 90 degree angle doesn't go on top of the extend part of the arm lever but underneath. My dad did wounded the spring a bit tighter than it original is. That fixed what many days and hours of my frustration in less than 5 minutes (That's how long it approximately took my dad to fix it and in one try)
Jul 12, 2008 | Hoover U6660-900 WindTunnel Bagless...
Mtd 22" Yard Machine Push Mower Logo
70 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
