Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE SOME ADJUSTMENTS TOO ELIMINATE SOUND, HOW?
  • Whirlpool Master
  • 3,051 Answers
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Posted on Apr 24, 2010
I've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Jul 12, 2012 | Electric Mobility Health & Beauty
Noise
Hi
Use a low pass line filter to reduce spark interference .
Mar 04, 2008 | Alpine MRP-M450 Car Audio Amplifier
My machine makes a "knocking" sound.
Needle bar probably catch the presser foot, because it does not return the the right position. Clean and oil the presser foot assembly. There is no tension adjustment there. It should move freely about 1 cm.
Dec 03, 2011 | Brother PE770 Computerized Sewing Machine
2001buell blast valve adjustment
The Blast has hydraulic valves that do not need adjustments, the motor is naturally noisy, and will sound like a blender full of rocks. Without hearing your bike in person it is hard to say for sure, but it is probably normal.
Oct 22, 2011 | 2001 Buell Blast
How to adjust valves for a 1970 triumph Tiger motorcyle ?
it's been a while, and there always a different spec depending which manual you got, preset 17 thou for exhaust and 14 thou for intake, run engine till warm , if still noisy let engine cool and tighten a couple of thou each, repeat if necessary, it sound wishy washy but it has worked for me in the past
Jul 26, 2010 | Triumph Tiger Motorcycles
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Motor seems noisy at 15K miles. Should the valves be adjusted? What are the intervals between valve adjustments on this model?
Yes valve adjustment is a requirement. You need a good repair manual, unfortunately I do not have one for your model, but your local Triumph Dealership should be able to answer your question about the intervals. I thought it was only done when required, but I am not an expert on Triumphs.
Jan 17, 2010 | 2000 Triumph Sprint ST
Noisy compressor
Compressors are availbe, sorry most compressors are sealed and can be replaced only
Apr 30, 2009 | Heating & Cooling
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
313 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
