Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Very hard to pull when starting . i think the compression release isn't doing its thing. how to adjust. homelite 54
    President:
  • 2,220 Answers
If defective it must be replaced.
Starter Handle difficult to pull:
1. Remove the starter cover.
· Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair or ordering any parts; if yes continue.
· Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
Homelite Lawn trimmer HLT26CDNB hard to pull start cord. Seems to be pulling against compression.
Take the spark plug out and see if it still hard to pull, if not it might have been the cylinder was flooded.
Mar 17, 2015 | Homelite Garden
Sometimes it cranks real hard and wont start has a new battery but it seems like the compreesion release is mot pulling down how do I fix this?
Compression release for the rear cylinder was my problem.adjust the slack out of the rear cable and see if that doesn't solve the problem.it doesn't take much,and try not to over adjust.
Jun 26, 2012 | 2001 Suzuki VL 1500 Intruder LC
Craftsman 24 HP 42" mower...has always been hard
If it has the Briggs or Kohler engine, it has a built in compression release. If the release isn't working properly, it will be hard to start. It mimics a weak battery. One remedy to enable the compression release to work properly is to adjust the valves. They need to be adjusted periodically. Briggs has all the valve clearances for all their engines in an easy-to-use chart. I will give you valve service instructions and then the engine chart with all the valve clearances.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
May 14, 2011 | Craftsman Garden
Lost OM, starting question - Homelite 10655 chain saw
The compression release should be a metal button that projects from the cylinder head and extends out from the cylinder cover so that it can be depressed before starting. There should be an immediate lessening of compression when pushed. If no such result, the release mechanism should be removed and cleaned, or replaced. Proper starting is to pump the primer button several times to fill the bulb with fuel, then set the choke closed, the ignition on and set the fast idle on the throttle. Pull the engine through several times until it pops, then release the choke part way, and try to start. Don't pull the throttle during this as it will release the fast idle setting. Once the engine fires, the compression release should self-reset for maximum compression. Hope this makes sense and helps!
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Had difficulty starting chainsaw DCS4610 for the first time. Think it was flooded. Problem now it wont idle.
Is this a new saw? If yes return it or at least ask for a recommended repair facility. Your saw is actually a Dolmar (owned by Makita) and a fine saw. In order to meet EPA requirements they are set very lean (many 5100s seize with factory settings). To protect your investment and not invalidate your warranty I recommend it be adjusted by the
professional recommended by the merchant where you purchased it or one recommended by Makita.
The starting procedure is probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Most new owners miss opening the choke after it tries to start or do not hear the pop when it does and flood the saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
New Homelite 16" chain saw is difficult to impossible to start.
Read and follow the start procedure in the manual, most say to open the choke once the saw attempts to start. Most operators miss this or do not hear the cough and flood the saw. Your manual is probably similar, if not successful with the following maybe time to return it. One thing that might impact starting, what is your elevation? Your saw was setup at near sea level, if you 4000' it may need an adjustment. The store where purchased will probably recommend someone if asked.
Start Procedure
Cold:
Warm:
Lou
Apr 02, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Lost my manual. Forgot how to start the darn thing?
Might it be beneficial to include a model number where the answerer cannot see the item in question? The embedded numbers (heading) are often someone elses best guess.
Start Procedure
Cold:
Warm:
Lou
Mar 24, 2010 | Homelite ZR10926 16 Chain Saw
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
FR- 2.0 14'' Factory Reconditioned My
I am going to assume you are following the warm start procedure in your manual. Most start problems with 2-cycle engines are caused by flooding.
Before you shut if off roll it to the side and loosen the fuel cap (vent tank - leave it loose until restart) Better? Repair fuel vent. No better carburetor needs small adjustment. This explains it better than I can but you will need to experiment some.
Just because this is the most likely cause:
Start Procedure
Cold:
Warm:
I hope you found this helpful. You can reply below if you need additional help.
Lou
Jan 17, 2010 | McCulloch Garden
353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 03, 2009 | Husqvarna Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
175 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
