Question about Hitachi 53FDX01B 53" Rear Projection Television
Aspect ratio problem
When i change the aspect ratio, the top and bottom bars are gray, not black
  • 3 more comments
  • distinctbuil Apr 24, 2010
    you can't change the tv background, only the menu background
    can only change menu background, not tv background
    President:
  • 196 Answers
Enter in the menu and change background to black.
Posted on Apr 24, 2010
  • Radames Pagan
    Radames Pagan May 06, 2010
    change the aspect in full mode, if you see gray in the side your tv is in 4:4 format. put in 16:9 format at full.
I moved my TV this afternoon and now there is a dark border at the top and bottom. How do I fix that
Widescreen letterbox and black bars How to wrangle TV aspect ratios
It would be helpful to post brand and model of equipment.
Possibly the aspect ration has been changed. Some remotes have buttons which alter this (sometimes a format button, sometimes a p button.)
Jun 10, 2017 | Televison & Video
Replace chip for white dots now have two black bar top and bottom model wd65735
Probably ok. Check the picture ratio or format settings to see if the bars go away when aspect ratio is right setting.
Feb 06, 2015 | Mitsubishi WD65737 65" DLP TV
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
When using HDMI input from Blue Ray DVD Player DMP-BD-35 I see black bars at the top and bottom of the TV screen 9JVC LT-37DS6BJ) despite changing the aspect ratio of the DVD player
The aspect ratio is higher from the player that what the TV can take in the resolution level that you are set up in. This is normal with some HD TV sets.
I have see this type of thing with some models of HDTV sets, and with low end Extended Defination TV sets.
Jerry G.
Dec 04, 2008 | Televison & Video
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Hitachi 53FDX01B 53" Rear Projection Television Logo
139 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
