Question about HP Pavilion A610y PC Desktop
Te power button blinks when i turn it on, monitor says no signal
When i turn my computer on, lite blinks monitor says no sinal
  • 781 Answers
You can test if your monitor is the problem by simply replacing monitor for known good or installing the suspicious monitor to a known good tower. replace monitor if found to be the problem.
now, first make sure you have the data cable gong from your monitor to your video adapter (on your pc) properly attached.
if data cable is properly attached...
that means that your video card has likely failed to the point of no being transmitting any data signals to monitor, ergo the message that you get.
replace the video card for known good video card, price is about 20 - 150 dollars.
Posted on Apr 24, 2010
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Monitor won't turn on power button blinks blue
Your computer is not POSTing and the monitor has gone into standby mode as it is not receiving a signal from your computer. My published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! will get your computer working again!
Happy testing!
damnor01
Nov 27, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Power will not come on, power button blinks
Once the monitor is not turning ON and the power button is blinking, this is an indication that the monitor is not getting an analog or digital signal from the computer.
Try to turn off and turn the computer back on, if same problem occur, try to connect the monitor into a known working CPU. If it works, then the problem has something to do with the computer. You may need to remove the video or graphics card from the computer, remove the dust using a clean cloth, and re-seat the video card into the slot.
Or you may try to connect a known working monitor into your computer.
Thank you and good luck!
Jun 21, 2010 | Envision EN9410 19" Flat Panel LCD Monitor
A7V 400MX ASUS Mother Board: Problem
i had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Mar 15, 2009 | ASUS A7V400-MX Motherboard
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
No display but only the light of powe switch (on/off) blinks and after some time it comes back (could be te signal problem??). Please help on this regards.
i have found a solution. when this is happening press the menu button rappidly. the on/off will occur still but after a few tries the monitor will stay on but you will have to repeat this if the monitor turns off. it seems to stay on when your system goes into stand by
Aug 31, 2008 | Acer AL1717 17" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
HP Pavilion A610y  PC Desktop Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
