Question about Husqvarna Chain Saw 20" Bar
How can I tell what year my 357xp was built - Husqvarna Chain Saw 20" Bar
    President:
  • 2,220 Answers
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
I have a troy bilt rototiller horse, serial #7146C. Can you tell me what year it is?
Go to the Troy Built web site, find the contact phone number, call them and tell them what you want to know. Give them the serial #, and they may want to know the model also. They should be able to tell you what year it was made. Hope this helps. I will Actually see if I can find out the info for you. I will be right back. Sara I just talked to troy built, this is not the serial # this is a model number if you can check again for the complete serial# I can get you the year your tiller was made.
May 01, 2016 | Troy Garden
Year built
Your title deeds should show you the year it was built. Otherwise there is some good advice on this page.
http://www.landregistry.gov.uk/public/faqs/can-you-tell-me-how-old-my-house-is
Aug 20, 2014 | Dishwashers
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Hi, I have a Husvarna 357XP chain saw. It wont start. Checked whole thing: Compression, bore , piston Carburetta Spark plus fitted new plug Mixture strength correct. Fule flow fine It was working...
take the plug out and warm it up inside your oven at 125 degrees for ten minutes. reinstall and try again
it works for me and tells me the electronic coils is starting to go bad
Aug 29, 2010 | Husqvarna Garden
I need to know how to adjust the bar oiler on my husqvarna chainsaw
A link to an OM for a 2005 Husqvarna 357XP/359 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
The procedure is on page 35.
CAUTION: It only has 3 positions; forcing it beyond the stops may render it inoperative.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Aug 13, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Year of equipment based on serial/model#?
The serial number on Carrier units tell you when they were built. The first two digits tell you what week they were manufactured. Digits 3 and 4 tell you the year.
Oct 15, 2009 | Carrier 38CKC042 Air Conditioner
Chain oiler 357xp
when you say that you changed the gear,was that the plastic one?check the other gear that is on the pump itself.make sure that it isn't worn.then make sure it spins freely.if it doesn't that will be you problem.cleaning them has never worked for me.........just replace it and the plastic gear.with both being new you should have no problems with oiling.the little pump gear gets scored up inside and they stop spinnig fast enough to work properly.hope this helps let me know if you have any questions
May 24, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
225 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
