Question about Canon imageRUNNER 400S Copier
Canon ImageRunner 400S won't stop printing
We have a Canon ImageRunner 400S, lately, when we send something to it to print, it will not stop at the requested number of copies. This does not happen every time. Is there an update to the drivers I need to download to fix this problem?
  • Canon Expert
  • 287 Answers
Canon ImageRunner 400S won't stop printing - fileicon_unknown.gif PCL5e-c_6_v8.20_v6.20_setup.exe
I would suggest reloading the driver ets. I hope this link helps. Otherwise the problem you are experiencing seems like a function {or malfunction} of your network. After 20 years of doing this stuff, I reflect on how your dillema and cannot imagine any "hardware " driven problem. So I agree with you that either need an update or to reinstall the driver. Take care and good life! :-)
Posted on Mar 24, 2008
  • jeff heightchew
    jeff heightchew Mar 24, 2008
    I am sorry, after reviewing my attempt to send you a hyperlink to the most recent PCL driver if appears that either I don't know how to o it properly or it is not possble to make an easy link for you within this venue. The Canon website of course has the most recent drivers for all of their equipment I hope this helps.
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
How do I automate the stapler feature when I send a document to the printer?
Stapling is usually listed under "finishing" option when printing. Good luck.
Mar 10, 2011 | Canon imageRUNNER 400S Copier
I am using canon ir 400s copier machine the copier did not show any error but the copier it work but the printing time its did not printing
there may be problem with primary charging roller. to replace the primary charging roller, take out the drum unit, remove plastic cover, remove three screws of the shaft plate, take out the drum,detach primary charging roller from stand and replace .
Feb 11, 2011 | Canon imageRUNNER 400S Copier
Ir6000 error code e246-0002
well seems like Your copier print board is faulty or some loose wiring. also posible if some fault in counter pcb
you need to send it back for servicing to the manufacturer
hope it helps, thanks
Jan 11, 2011 | Canon imageRUNNER 400S Copier
Can't access system settings on Canon imagerunner 400s
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Hello sir, here we are having a canon ir 400 xerox with printerboard. Now we are facing a problem with it. that is, it self it is printing 3 papers when we switched on the mechine. ( also printing when...
Best I can determine is that the print board may need rebuilt. This is an older model and the print board on these all need rebuilt once at least. Nation-wide repair service can help you. You can remove the board and send it to them. they will repair for about 375.00 1 800- 798-1814
Jan 05, 2009 | Canon imageRUNNER 400S Copier
STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Canon ImageRunner 400S - Clear RIP job
I think I can help but its been a long time . you need the clear the print jobs at the PC first then the print serveron the copier. turn the copier off and on, as it starts to warm up press the print button, now when it ask if you want to start setup press yes...scrool around till you see clear print server and say yes reboot.
good luck
Oct 24, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
124 people viewed this question
old marine
old marine
