Question about Refrigerators
Button don't work
Button contolling the ice and water dont work when pressed
    Sergeant:
  • 239 Answers
Maybe the door switch is bad
Posted on Apr 25, 2010
Don't understand nintendo 64 controller to translate cheat codes with contoller keys/buttons
the button on the back of the controller is the Z button, the yellow buttons are the C buttons, the A button is Blue and the B button is Green, you use the D-pad, (the left part of the controller), to enter the directional inputs that the cheat asks for
Mar 30, 2012 | Nintendo 64 Console
The control lights of my wii just keep flashing but the controls don't do nothing to the wii, I try new bateries and still don't work
First, remove the battery cover for the Wii Remote
Then open the small panel on the front of your Wii console
While holding down the sync button on the controller, press the sync button located under the small panel on the console, wait a moment, your contoller should then be synced.
Jul 22, 2011 | Nintendo Wii Remote Controller
Icemaker does not make much ice
Could possibly be a temperature sensor, but most likely the heating coil that heats the ice receptacles is burned out. The ice maker needs this heater to momentarily heat the walls of the ice receptacles so that the ice will easily come out of them.
Sorry, but this usually means a new ice maker. They're pretty easy to install and really don't cost that much (less than $150).
Jun 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
Dec 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Not getting any ice
Im gonna be bold and take a stab at this problem. (since I dont see anyone else doing it).... Lets see, Has anyone tried turning the freezer setting down a notch? Try that and give it a day. My theory is; ALL ice makers have a thermostat in them and if they arent at the right temp than they will not go into the "haverest cycle". When you press that button you force it through that cycle. Therefore if your freezer is cold enough, The ice maker won't make ice! This could also be a sign of a BIGGER problem..... Things to look for to help solve problem;
**Can you hear a fan running in freezer?
**Is there any snowy frosted ice on back wall in freezer?(at the bottom area)
Some more info at my website at:
http://www.houstongofarappliancerepair.com/Refrigerator.html
This will give ya a wee bit more information....
Goodluck, Brian
Jun 07, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
