Question about Garden
Engine[Kohler Magnum 18] starts and runs fine, but no power under
Engine[Kohler Magnum 18] starts and runs fine, but has no power under grass mowing load. Have redone fuel system, drained out old fuel, new filter and lines with no improvement. Suspect it may be coil,condenser,points, or spark plug lines. Suggestions? I need part #'s for the coil and points/condenser.
I live on an island with limited engine parts
Thanks,
  • 109 Answers
SOURCE: have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
Posted on May 28, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
SOURCE: no spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Posted on Aug 29, 2009
  • 138 Answers
SOURCE: i have a craftsman gt 6000 with kohler 18 hp
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Posted on Sep 13, 2009
mickey813
  • 472 Answers
SOURCE: Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Posted on Oct 12, 2009
My 25 horse power cub cadet mower starts and runs great until you try to mow with it and it has no power. At half speed it mows fair but in heavy grass no power. Any help app. Bill
be sure the battery is fully charged. be sure the blades are sharp. be sure there is no grass or string or wire wrapped around the spindles under the deck. be sure it is firing on both cylinders . be sure the belt is in good shape .
Jul 05, 2017 | Cub Cadet Garden
Engine runs rough under load
how old is the motor
4 stroke with valves or a two stroke ?
blades
spark plug , coil , air fuel mix check valves
re check governor setting
if grass is way above the front height of the frame it will struggle
raise the height first to max on the first run
then lower
or use a grass trimmer to knock the level down before mowing
May 17, 2016 | Garden
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have a sears 917.255960 with an 18hp.kohler engine.cranks over.no spark
Sounds like you may have a ground..or bad switch follow the wire on tne back of the switch that is on the stop or off position..it should go and be attached to tne engine body...when the switch is in the off stop position it grounds the wire to the engine and kills tne power..disconect it and try starting, if it starts,, you have a bad switch..if not your coil is most likely bad...and will need to be replaced good luck
Feb 21, 2015 | Sears Garden
Fuels ok 16 hp kohler on Scott mower cuts grass for about an hour then sputters and won't run under a load let cool down for about 20 min and it's fine
you need a valve job done on it valves are not seating causing lost power and is superheating engine take in to shop 100.00 per cylinder
Sep 13, 2014 | Garden
Kohler engine oil leak
Could have blown a seal however before checking for that I would check the drain plug and filter seating if you changed the filter. Make sure the drain plug is not cross threaded. You can run a little low but should never over fill. Hope this will help. Most of the time if over filled you will get some smoke as well.
Apr 25, 2014 | Garden
Mower is electric. cord is fine. was mowing great, had it on highest blade level due to high grass. just quit completely. blade and chute are not clogged. there is power to mower.
If you were cutting long grass it sounds like you may have burnt the motor out. It may have over heated. they are not made to cut long grass. You don't say whether the motor runs but not the blades if this is the case you may have sheared the shear pin in the blade assembly.
May 02, 2013 | Black & Decker 18", 6.5a Electric Mower
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
