Question about Toshiba 57H81 57" Rear Projection Television
Convergence my tv seems like it has double vision, I have replaced both convergence IC chips, but that did not solve the problem, what would suggest be the next step
  • Toshiba Master
  • 8,617 Answers
Have you checked the resistors next to the ICs these sometimes go open when the ICs fail. also a fusible link may also be open. Check the resistors near the ICs and also check anything in that area that has a FLin its location number such as FL231 and etc.
Posted on Mar 23, 2008
  • Chris Sep 20, 2011
    same thing here, toshiba 57h81, put new ics in, still bad.. checked all fuses and resistors, all good....then i changed the digital cnvergence (silver box that plugs in board) and BAM! works now..
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Tip
"double vision" caused by bad solder points on convergence chips (check before...
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able to smack the side of the tv or tap the heat sink for the chips and it corrects the problem than chances are the chips are fine butone or more of the solder points are bad. When I looked at the joints for the chips I noticed hairline cracks around the base of the joint. Re-soldering the joints for the convergence chips solved my problem.
on Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for choosing FixYA, Big Irish.
Nov 23, 2009 | Televison & Video
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Double vision
The double vision is from bad convergance ic's and posibly some support resistors or pico fuses. if you are not an electronics tech I suggest to have one do it. the ICs can range from $45.00 to $60.00 each and is suggested to replace both of them. some mitsies had one IC which I cant remember how much it was. tech charges vary. some prices may be $150.00 to $300.00 shop around.
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Double vision with a lot of yellow color
This looks like bad convergance. If only one color is affected it may be one of the convergance IC's. It is best to replace both IC's though. If you change the IC's then check the resistors next to the IC's. Use the exact part numbers. STK392-110 IC's can be upgraded to a STK392-180 for better heat strength. (That is why they blow, too much heat generated. Use a liberal amount of Silicone Heat sink compound.) A shorted IC will usually blow a resistor. If a bad resistor that isn't changed it will look like the new chip is bad. Make sure that you use the same wattage and the exact value (Ohms). Your convergance will not be right with an off value resistor. This info works for about any other brand Projo TV. Cheers, Lee http://www.crazycomputers.com
Jul 21, 2007 | Hitachi UltraVision 55HDS52 Television
Toshiba 57H81 57" Rear Projection Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
