Question about Hisense Televison & Video
The TV's lock feature is enabled. How do I unlock the TV to access channels?
    President:
  • 196 Answers
Is a RCA tv? put enter in menu and put FPoption in off possition
Posted on Apr 24, 2010
Can i get ur help or not am still waiting on a reply on my question about my philips tv
videos
9k= 1:54 How to lock and
unlock ISF modes
on Philips TVs?
TV Calibration with Darko YouTube - Feb 15, 2016 z 0:45 How Do You
Unlock A Philips
TV?
Wen Wen YouTube - Aug 14, 2017 9k= 2:23 PHILIPS HIDDEN
SECRET SERVICE
MENU/MODE
Carl Cosmos YouTube - Apr 15, 2016 2q== 1:09 How to unlock your
Philips
iTech Unlimited: Unlock... YouTube - Jan 30, 2015 z 1:20 ********* a locked
Philips 25u604 TV
for composite in.
CNLohr YouTube - Dec 23, 2012 9k= 0:28 How to Access
Hotel mode on
Philips TV
Carl Cosmos YouTube - Aug 31, 2016 9k= 1:14 how to unlock a
hotel tv/remove
hotel mode, use
HDMI on hotel tv
draai een keer in het rond... YouTube - Nov 16, 2016 9k= 0:46 HOW TO UNLOCK
PHILIPS MONITOR
CONTROL
Vrushank Maharajwala YouTube - Apr 30, 2013 z 2:45 Unlock Hotel TV
inputs
Channel88 YouTube - Dec 20, 2016 z 1:47 How to make your
hotel television,
like LG TV, allow
you to change ...
Margebird YouTube - Mar 24, 2016
How to lock / unlock a channel in Philips TV? - Philips - Canada
https://www.philips.ca/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
How to lock / unlock a channel in Philips TV? Press the 'MENU' button. Press the cursor right. Press cursor down to select CHANNELS. Press cursor right. Press cursor down to select CHANNEL LOCK. If the PIN code is correct, the channel list reappears. Select the channel with the cursor up/down and press the 'OK' button ...
How to lock / unlock a channel in Philips TV? ' Philips
https://www.usa.philips.com/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
Locking/Unlocking channels in Philips TV ' Philips
https://www.usa.philips.com/c-f/.../lockingunlocking-channels-in-philips-tv
  1. Cached
Published: 2017-03-02 ' Make sure remote control is in TV mode by pressing 'SELECT' button repeated until 'TV' lights up green.
Jun 21, 2018 | Philips Televison & Video
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
How can i turn on locked tv?
If it's locked, that means it has a child lock feature on it. MENU settings have be adjusted to unlock it. AND yes you can access the MENU without being on a channel. Turn ON, then go to your menu. Adjust your lock settings accordingly and VOILA you should have it back on in no time. You should be able to do it from either your remote or buttons on your TV. Let us know if this works.
Mar 09, 2011 | RCA L32HD41 LCD TV
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I unlock the tv's settings?
you should be able to go into your menu options. under channel set up. there should be an add or remove channel option and if your set has a locking feature it should be right in there that you'll find the unlock feature, Other than that, if you dont find it really the only other locking feature would be in your menu, under the parental control setting, this is another way to block and unblock channels as well, good luck. feel free to ask me any other questions you have!
Mar 24, 2009 | Zenith H27E55DT 27" TV
Televison & Video Logo
232 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
