Question about Maytag MMV5165 Microwave Oven
Maytag over the range microwave model mmv5165baw purchased in 2007 turn offs the power after 4 minutues of continuous use. I have take out the powercard from plug for 10 minutues in orders to fix power problem. Please advise.
Ours runs for 2 minutes and turns off for twenty then "resets". Gee I'm So glad I didn't buy the one that was $70 cheaper(NOT) that one would probably still work! Had this only one year and it's the Last Maytag item we will ever rely on!
Good luck finding a fix, it's a common problem apparently!
Posted on Sep 22, 2010
Maytag mmv4205bas
The problem is more than likely in the keypad control board, pricing on this part should be checked before going ahead with repairs.
Jun 29, 2012 | Maytag Appliances Over-the-Range Microwave...
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Turns off after 2 to 4 seconds
Hi, am afraid it sounds like the power control module is bad. The new module retails for about $155, APP has it for $129. You can try replacing the module, or purchase a new microwave. Over the range microwaves start at about $280-$350 and can go up to $1000 depending on brand/features. Microwave installation is typically $35-$50.
Mar 23, 2011 | Maytag MMV4205 Microwave Oven
Maytag Microwave over Oven: comes on with lite and table turns; loud continuous noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 21, 2011 | Maytag 2.0 Cu. Ft. Over-the-Range...
We recently had a power outage & my Maytag Microwave model #CME90108BAE is the only appliance that will not turn on. Is there a fuse with this model?
the fuse is usually mounted inside the unit on the same side as the control panel near the back end where the power cord is.......the cover must be removed to get access to it.
Jun 25, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
New maytag power shuts off and comes back in half hour
Depending on the model you may need a 15 or even up to a 20 amp circuit to operate the microwave. Check the installation instructions to be sure. What is most likely happening is the circuit in your home is not powerful enough to run the load of the microwave oven. If this is the case it could be dangerous. I would strongly recommend you have an expert examine the house wiring prior to starting the unit again.
Apr 20, 2010 | Maytag MMV4205 Microwave Oven
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag microwave just died.
Take it back to the store and make them do something about them. If they dont then file a complaint with the BBB no reason for you to have to deal with this when it is there problem. It sounds like there is a venting issue and more going on
May 19, 2009 | Maytag Appliances Over-the-Range Microwave...
GE Profile Spacemaker XL1800
pull the cover off of the microwave and check for anything loose. ie fan bracket covers. check the 4 nuts that hold the magnatron in also. if that doesn't fix it maybe you can go to an appliance repair place and see if that have a magnatron tester which is just a piece of plastic with 4 bulbs in it and if the magnatron is working properly with that tester in the it will look like a red strobelight going off in the microwave. if not then your rumbling noise is the magnatron getting ready to go out good luck
Dec 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5165 Microwave Oven Logo
152 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
