Question about Kenmore 24 in. 16049 Built-in Dishwasher
Does not fill with water
The washer does not fill with water. Partially fills but no where near enough to run properly and clean the dishes.
  • 192 Answers
The water level detection is done via a small plastic pipe from the bottom of the machine that fills with water and causes the air pressure in the pipe to activate a micro switch in the water level detecter. The pipe can be disconnected at the bottom and gently blow into the pipe. If you listern carefully you can hear the micro switch click. The pipe must not be blocked and in some cases the switch contacts could be burnt. The water level is factory set but can be adjusted on the water sensor. Replace if necessary.
Posted on Apr 24, 2010
Why doesn't my washing machine fill with enough water to wash my clothes properly any more
Unplug the washer for 10 minutes and let the board reset. If it still is not filling correctly, then the pressure switch or load size switch is faulty. Appliance Parts Suppliers sells Samsung Parts in Bolingbrook, IL sells samsung parts.
Aug 02, 2014 | Samsung Washing Machines
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Maytag Dishwashers
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
I have a six month old Bosch dish washer and 8/10 times the powder is not disolving?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Evidently the detergent cup is opening? Here are some of the possible causes; 1. Low on water (fill the machine, let it start and see if the unit has enough water). Sometimes the screen on the fill valve get partially clogged and slows the flow and when the timer engages and therefore enough water was not installed. 2. Defective fill valve (partially sticking valve sometimes will not let a unit get the proper amount of water before the unit starts and therefore the powder in not dissolved). (3)Any detergent will generally dissolve when contacted with water, unless is has had previous contact with water or is old....
Aug 05, 2010 | Dishwashers
Dishwasher does not clean the dishes properly
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24 in. 16049 Built-in Dishwasher Logo
159 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
