No singal cable hooked up - Televison & Video
Mitsubishi VS 50607 big screen no picture and no sound blue black screen
HELLO. your problem is mostlikely in your singal u are putting to it . where u have it hook up to. or in your setting in your menu. are not right look at where you are put or cable in or ant in and put it on A or B. THEN WITH YOUR REMOTE BRING UP THE MENU AND GO TO SET UP THEN TO SEE IF YOU HAVE IT SET TO CABLE OR AIR.? ONCE YOU KNOW WHAT IT ON SET IT TO WHERE YOU HAVE YOU CABLE OR ANT HOOKED UP TO. (A) OR (B) then run the auto program. and see if it work's hope this help's u . rember to vote for me thank u.
Jun 08, 2011 | Mitsubishi VS-50607 50" Rear Projection...
How to hook up cable phone to work fax and answering machine on a cannon Pixma mx340
From the wall your phone cable should go into the fax/printer. Then a phone cable should go from the printer to your phone.
There should be icons next to each jack on the back of the printer which indicates where to connect the cable.
It should work from there, but you might have to go to settings and set up the fax settings such as how many singals should it ring before the fax picks up the line.
Nov 22, 2010 | Canon PIXMA MX340 Wireless Office...
No singal to tv whith av cable we tryed two cables but nothing and we also tryed difrent tvs
Do you get anything via HDMi?
Hook back up to your TV again, turn TV on and turn PS3 on, once you hear your PS3 make a beep, press and hold the power button for 5 seconds and it will then beep again, at this point take your finger off the button.
this resets the PS3 resolution and output settings, so if it was just a resolution error this will fix it and you should then eventually get a signal on screen.
But after doing this and you still get nothing then it's time to look at it being an about problem with your unit relating to the motherboard.
Hope this has helped.
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Battery light stays on
there is a singal wire that hooks to the alt check to see if it has come off our broken this wire is for lamp. if it is hooked up then there is a voltage regulator problem good luck kdc
Dec 24, 2008 | 2000 Ford F250 Super Duty Crew Cabs
95 ford explorer, turn singal relay location
If you place the handle against your ear and the other end on each relay in turn, you will find it.
Apr 18, 2017 | 1995 Ford Explorer
What do i do
You most likely need a stronger antenna.
Sep 01, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
