Question about LG WM-2277HW Front Load Washer
Error code looks like an upside down FE - LG WM-2277HW Front Load Washer
The upside down F is actually a lower case t. The fault code indicates a faulty thermistor.(temperature sensor) The first step in troubleshooting is to unplug the unit for 10 sec. plug in turn on and select rinse/spin mode and no spin option to drain the water.If this does not solve the problem you will be directed to a service company.
Posted on Apr 27, 2010
I had this code "upside down F E" and the problem was the Thermistor. I replaced it myself and it was a piece of cake. Here is a link to the part I bought. http://www.repairclinic.com/PartDetail/Thermistor/6322FR2046C/1268202
It only cost 8.00 and took me 15min to replace.
Posted on Oct 14, 2011
  • LG Master
  • 43,501 Answers
This should help you to figure it out...
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
heatman101
Posted on Apr 25, 2010
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Upside down backwards fE comes on. We had a
The error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)...
If you still get the FE test..call for service..
BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open.
CLICK HERE for the WM series service manual that may help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2009
  • 410 Answers
SOURCE: error code upside down FE
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. You can search for the meaning of
the error code on the site.Don't worry about the
timer, they hardly ever go bad.Good luck with it.
If I have helped you, please rate my advice on fixya.
Posted on Nov 27, 2009
WHAT DOES A UPSIDE DOWN FE CODE MEAN ON A WM2277HB LG WASHER FRONT LOADER
I think it is actually a 'tE" error code. Thermistor error. Pretty easy fix. And under $10 part. Repair videos exist on YouTube, repairclinic.com or appliancepartspros.com. I would suggest that you look at videos and see how they all suggest you do the repair. Top off, control panel off, front off. Fairly complicated but very doable. If you get the part and study the parts diagrams, you can do the part replacement by turning washer on its side and do replacement from underneath. Takes a little feeling around but much easier.
Feb 16, 2017 | LG Washing Machines
I have code that is a upside down FE THE CODE in the book shows a control error call service and i have and they are not sure what it is just guessing it is the control board but not sure of that
i would say it is the 'hall' sensor, the motor position sensor. this is a very common problem and easy and cheap to correct. check or repairclinic.com or appliancepartspros.com for great repair videos and the part is less than $20 on eBay from appliance parts pros. takes less than 30 minutes. all thru the rear of the washer. look for videos from the above for how to. good luck
Dec 26, 2015 | LG WM2050C Front Load Washer
Have a error,not LE, but looks like an upside down 7 with a line thru the middle, then E???
often referred to as an 'le' code. looks kinda like an upside down 'F', correct. replace motor position sensor--the hall sensor.
Mar 22, 2015 | LG Washing Machines
LG front load washer is gettign an error code of and upside down F and E - not sure what it means?
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Dec 28, 2010 | LG WM0642H
Trouble Code
Hi
Thanks for using FixYa. Error FE is an overflow error which indicates that the water is overflowing i.e. the water level frequency is over 213. To start with you’ll need to check the water inlet valve assembly and replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | LG WM-2277HW Front Load Washer
Dishwasher won't run much of the cycle.
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Jan 26, 2010 | LG Dishwashers
Sep 23, 2009 | LG WM-2277HW Front Load Washer
Error code upside fe
But U still haven't told us specifically what the issue is with the device. So how can anyone help you?!?!?!?!?!
Sep 12, 2017 | LG Washing Machines
OLYMPUS FE-240 digital camara can't use port to unload photos
You better take a closer look. I know my friend Dave always looks in the wrong place. Here is a link to you manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1284
Radio Shack has cables of all sorts if you've lost on but it sounds like you just need a map and some magnification.
Paulpsps@aol.com
Nov 07, 2007 | Olympus FE-240 Digital Camera
LG WM-2277HW Front Load Washer Logo
4,110 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
