Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool cabrio washer has starting to "chirp" when agitating
My Whirlpool cabrio washer has starting to "chirp" when it is agitating. Not a cyclical sound, but a random chip. It appears to be agitating fine, just the sound is concerning. Any suggestions?
aborcass
  • 2651 Answers
SOURCE: Two dollar coin fell into a space between agitator and a drum.
you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
Posted on Nov 20, 2008
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
Posted on Jan 09, 2009
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
  • 4088 Answers
SOURCE: need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Posted on Oct 08, 2009
Testimonial: "Thank you so much. I had figured out how to unscrew agitator, but was affraid to pull 2 hard as I thought I might break it. Your 2 step method works"
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
Mar 29, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
    Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
    Manual and parts list click here.
    Hope this helps.
    Zeppelinx12
    Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My cabrio washer sounds like it has coins under the basket when it goes through the spin cycle. how do i get them out?
    Assuming that this is a Whirlpool Cabrio, see the following Whirlpool Service manual. It has sections on how to pull the agitators, tub etc.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
    May 11, 2010 | Kenmore 22422 Top Load Washer
    My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
    They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
    May 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Wtw6300sw1 agitator moves clockwise no counterclockise mov
    This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
    Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
    My washer will not spin or agitate clothes it is a cabrio and just started to day will it pumps water in and out but will not spin or agitate.
    Most washing machines work with just one motor... it runs clockwise to run the transmission as an agitator and counterclockwise to run the pump and to turn the whole drum to spin dry.  The belts often look loose but are fine.   Check that the belts are on... if they are then the motor may not be running in reverse.  if that is the case then you need to diagnose whether the motor is the problem or the controller.  Check the centrifugal switch in the motor too.
    Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Need to remove agitator to remove lodged medallion
    Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    121 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
