Question about Coleman Powermate Premium Plus 6250W Portable Generator
I tried to start my new coleman powermate 6250/5000,
Added oil and gas, I could not get it to start or run. I sprayed gas into carburator throat and it started but would not run. yes there is oil, all wires are connected, opened fuel valve. Choked it but will not run. It has oil low shut off feature, could this be my problem?
  • 5,603 Answers
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Posted on Apr 27, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
Unit will start at full choke but will not stay running with choke off,will load up on full choke and stay running around 3/4 choke
HI,
Turn off the gas and take the bowl off the carburetor.Look for water bubbles in the gas that spills away. Water will float like little balls on gas. If so drain gas tank put in new gas with some HEET added. While you have the bowl off spray up and around the bottom of the now exposed carburetor.
Pay attention to spray up the small copper tube in the center of the carb.
Clean out bowl and put it back on. Turn on your gas. Look for leaks around the replaced bowl. Good luck.
Jan 29, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 6250 generator - shut off generator at 11pm after v4 hours normal use. At 5am, wouldn't start, pull rope wouldn't move to start. A few hours later while draining oil found mostly gas...
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Oct 21, 2009 | Coleman Powermate Powermate 5000W...
I have a coleman powermate generator 5000 in from 2006. Has never been started. I tried to start, filled the oil/gasoline and It would not start. What can I do beside's taking it in for service.
Remove the air cleaner and spray some starting fluid into the carb. If it starts then ok if not then remove the spark plug and check for spark.
Keep posting until its fixed. Give the model number PMxxxxxx.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Feb 04, 2009 | Coleman Powermate Proforce 2500 Generator
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Engine dies
Your carburator is gummed up !
Take the float bowl on the bottom of the carb and spray the main fuel jet out with cleaner, do this to the idle needle valve also. If that don't work pull the carb & take apart & soak overnight in parts cleaner & blow out all ports & orfices with compressed air.
Next time you store your generator with gas in it , use a fuel stabilizer !
Good luck !
Oct 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
635 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
