Question about D-Link DPG1200 Digital Media Streamer
Dpg1200 connected to tv computer can
Dpg1200 connected to tv. computer can"t find it software only can only look for router to dpg1200 direct connection not wireless,need wilrless software.
    Problem Solver:
  • 6 Answers
You need to install the CD onto the PC being used to stream the video/photos whatever....
That software when started up, will try to connect to the device. You need to run the wizard the first time to tell it what configuration you have.
Posted on Mar 28, 2011
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Can I connect Ethernet to the internet without router
This is possible a few different ways:
-Connect the switch directly to the modem and each computer, then pay your ISP for extra IP addresses for each computer, if they will allow it. Make sure that you secure each computer with proper firewall/security software as it will be directly exposed to the internet. This method typically will not work with ADSL or any ISP that uses a PPPoE connection.
-Install two ethernet cards in one of the computers. Connect the switch to one ethernet card and the modem to the other, then enable internet connection sharing.
-Acquire an older computer with two ethernet cards in it and install free linux based router software such as Smoothwall to create your own homebrew router that has all of the features of the pricy linksys/netgear/etc. routers and then some.
May 01, 2011 | Edimax ES 3116P (ES-3116P) Networking...
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to...
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | Linksys WRT160N Wireless Router
You need to have the router connected directly to the computer to do this setup. If you are directly connected to the internet you cannot communicate with the router and most everything will fail. Remember to set wireless security on the router, give a ssytem name and consider setting channels to 11 or so to not compete with wireless home phones.
Oct 03, 2010 | Linksys Computers & Internet
My Broadband keeps dropping 2 to 3 times a day , why
  1. If your computer is connected to the Modem directly. I would suggest you to call Your internet service provider first.
  2. If your computer is connected to the router. Connect it directly to the modem and check if you have the same problem
  3. If you find the problem is only when connected to the router. Check if your other computers connected to the router has the same problem. This is a test to find out if the problem is with the router or the computer
  4. If it is found to be Router's issue. Try resetting and reconfiguring. If it is still not fixed try upgrading the latest firmware.
  5. If it is the Computer's issue try changing cables, Update the NIC's driver software
Aug 17, 2010 | Computers & Internet
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
I tried 15 times to call and get help from D-Link support what a headache! I have a d-link router and I think it is causing a conflict between the 2 Now I get a windows error : There is an ip address...
I use the dir-655 router and have no problems. Follow the quickstart manual (folded page) that came with your device....and plug the DPG-1200 into the router using ethernet directly (only initially so you can set it up). Use DHCP so there should be no IP address conflict.
You can reset the box using the reset button next to the IR port.
Good Luck.
Jun 14, 2009 | D-Link DPG1200 Digital Media Streamer
How do I PING my router?
Hi Sparkle
Firstly to use direct TV all you have to do is open up some ports on the router .
Get the port numbers from The Direct TV Tech Support
I'll give you an alternate solution in case they are unable to provide you with port numbers
Please make any changes to the router from a wired computer using lan (any computer)
Solution 1 : Opening ports
1. Start ->run -> cmd -> Ipconfig
2. You will see a default gateway address (eg :- 192.168.2.1 for belkin or 192.168.1.1 for linksis , d-link etc) which is the ip address of your router .
You havent clarified which router you have .
3.Type this gateway address (only the numbers) on the address bar of your browser or type http://address
4. Well this will open up a router setup page for you
5. Once you are through in this page half work is done
6. Click on virtual servers under Firewall( again terminologies may vary from router to router )
7. Input the port numbers and IP address of the Direct TV .
You can find the IP address of direct TV on its dashboard .
Or alternatively find the ip addresses of your devices (computer , x-box) connected to the router.
On the rsp you'll find all listed IP addresses under the first tag and so find the ip address of Direct TV
8.Reboot router .
9. Reconnect
10.You can also change the channell on the router to 6 or 11 which will give you the best signal strength.
Solution 2.
In case you dont get the port numbers
1. Open the RSP as described earlier
2. Under Firewall you'll find DMZ Click that
3. Input the IP address of your Direct TV
4. Reboot Router
Note: This will put the Direct TV outside the firewall of the router
Hope this brings a spark to you and do let me know please.
Mar 25, 2009 | Computers & Internet
Router will not connect with on demand direct tv
I had the same problem. I fixed everthing by updating the router's driver. Try that and see if it works.
Mar 01, 2009 | Linksys WRT160N Wireless Router
D-Link DPG1200 Digital Media Streamer Logo
44 people viewed this question
Top D-Link Televison & Video Experts
David Payne
David Payne
Are you a D-Link Televison and Video Expert? Answer questions, earn points and help others
