Question about KEF Audio Audio Players & Recorders
My KEF Model 25B (Serial # 67119) emits a loud popping sound every time the bass signal/input is required from the sub woofer. Believe the popping sounds is coming from speaker. The popping sound comes on when the green light initially comes on. I'm not positive but I believe the popping is only when the bass is required not when the signal is not. I do know that the need for sub woofer ebbs throughout a song or movie. You can imagine how disruptive it can be. I have unplugged it to protect what ever is left of the speaker, and our ears. Thank You for any assistance!
5 Suggested Answers
SOURCE: Sunfire True Sub Constant Hum & Thump on Initial Signal
The problem in the subwoofer is at leat 4 bad components
degraded due to heat. Remove the module and ship to
Mr. Transistor 453 Opelika Rd. Auburn, Al 36830.
If your sub is thumping and not staying on at lower levels
I have the fix. Cost is $250.
Posted on Feb 09, 2009
  • 9 Answers
SOURCE: Speaker light in the back turns on(green) but no sound
Well, I will try and help. If there was a problem with any of the innards, ie your amp. It's most likely that the red light would come on ar some horrible sound would be emitted from the woofer. reguardless if there was any input. But let's troubleshoot this anyways.
If you are using the low level input (RCA cable) try hooking it up to something else, if you can. This will determin if it is at all the sub or if it's your amp. Then try using the high input. This requires the speaker terminals in the back. If it works, then we know there is something wrong in the path of low level inputs. If it does not, then we know it has to do with either the connection terminal or something further inside.
You can open your amp and check the solder at all the pin contacts in and around the inputs. If they appear to look stable and sound (no breakage or cracks) start looking at the circuit boards for tall tale signs of anything burnt. If you know haw to use a multi-meter, I would suggest using it and start at one end and check everything. Even though they may not look damaged, a resistor can become bad. If the Capasitors are bad, there will most likely be some spillage coming from it. Becareful and unless you have done repair work before. Don't attempt to replace it. If you put it in wrong and get a reverse charge, it could/will explode.
Aside from that, I don't know what else to tell you. Hope it helps.
Posted on Mar 21, 2009
  • 17 Answers
SOURCE: Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Posted on May 19, 2010
SOURCE: my kef psw 2150 sub
is probably faulty capacitors
you should check out this link: http://lug.demon.co.uk/kefrepair/?cat=1
Posted on Dec 05, 2010
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
I do not know how to connect the woofer KEF PSW3500 to the amplifier Denon 4310. BCC sold me a 1 on 1 plug, but the woofer needed to plugs (left and right).
Bass is mono directional in the main,and while your sub has a left and right input ( because a few amps do have left and right sub outs) only one of them is required (usually marked as MONO on the sub). You can also get a Y splitter phono adapter and connect the single cable you have to both sockets, which is how I have mine set up. This is most common
Dec 03, 2010 | KEF Audio PSW3500 Subwoofer
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
Quest subwoofer pops every 40 seconds or without any input. Does not produce any bass or output
Problem may be a blown internal amp module. Some JBL powered subs have this same problem, emiting a burst of noise from time to time even when no signal is being sent to them. I've tried fixing this problem before with only marginal success, even going so far as to install a small cooling fan inside the sub to control the overheating that can destroy these modules. If the module is blown, you can probably replace the whole sub for about what it would cost to repair it. Look into this carefully before you commit to a repair job.
Nov 29, 2009 | Audio Players & Recorders
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
How do I get more bass out of the system?
To get a better bass output from the sub. The best place is in the corner next to a wall. Doing that is called corner loading. Like you put a firecracker on your hand you might just get burned,buy if you close your hand...you will have to goto ER. And it is not a boomy sub. Small 5 1/4" woofers.You wand good bass? Take it back and buy klipche. Great sound and bass for a decent price.Or go all out and buy the Bob's Sunfire sub. and tick off all your neighbors. that little thing really pounds. I own two. When I played twister, My celing in my new home cracked. I got picts. If you want something simple like the 321,try Kef instant home therei <<spelling. Has a 10" sub.Bought for my father. Sounds great. Just 2speakers DVD/CD/Radio unit and sub.Simple one wire hook-up. and speakers.
Hope you are able to use this info.
Todd
Oct 29, 2009 | Bose Cinemate Digital Home Theater System...
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
53 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
