Question about Vacuums
Sharp R-1480. Microwave would not start - jarred door, and it heated and worked. Replaced bottom of the 3 inter-lock door switches. Turns back on - all seems normal. No heat (it does overall sound louder). Thanks, Mark mreel01@msn.com
    President:
  • 949 Answers
Hi Mark,
It sounds like you have a magnetron problem now or at very least a rectifier that is shorted.
The elevated sound level comes from one of those two components. But since you had a door switch problem I would lean toward the problem being internal to the magnetron. It is common for them to over draw on the circuit going through the door switch before they fail completely.
To test the high voltage components you need a good ohm meter, the magnetron should read under 1 ohm from terminal to terminal and infinite ohms from either terminal to ground. The rectifier or diode should read 0 or low ohms in one direction and high or infinite in the other. BE SURE THE POWER IS OFF BEFORE SERVICING!
Posted on Apr 24, 2010
Sharp r-530es microwave. when depressing door Pushbutton, the door will not open. (problem started itermittently but now will not open at all(unless I pull on the door to assist)
Hello there, the mechanism for opening microwaves is such that when the button is depressed it raises the hooks which hold the door back. In some microwaves the hooks also have another part which pushes the door out while some units have door hinges which have spring mechanisms which pushes out the door. Depending on what is obtainable on your unit the problem might differ. What you want to do is this, when the door is open press the button and see if the hooks which are supposed to hold the door in place move as expected but considering that the door opens when you pull the problem is more likely from the spring mechanism which is supposed to push the door out.
Try cleaning the hinges and the space in between the door and the control panel. Try this and let me know as any other process might require a replacement part.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Sep 21, 2011 | Sharp Vacuums
When you plug in the microwave the screen displays simply samsung and none of the key pads work. I unplugged for awhile and plugged back in. Everything worked and came on. That night in the middle of th...
It is possible in this case that the program controller unit is faulty as it is working erratically. Now if there is a possibility that insects have gone into the board sections itt can secrete and damage the board to short at times. So open and remove board , clean using petrol on the board and reset. check all teh connectors , teh door switch and the front panel-- this is also a suspect if there is no response.Please check the cost of a new board to thenew oven and deccide.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
Jul 08, 2011 | Vacuums
I have a G.E 1.0 Microwave Model JES1039WF02, It has power on the panel but I see a message that says -F3- It will not start or do anything when the buttons are pressed. There is power running to it....
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
May 17, 2011 | Vacuums
Cleaned inside of microwave with all purpose cleaner, now it runs but does not heat up food.
Remove the plug from the power point and make sure that you completely dry the inside of the microwave with a clean dry cloth , keep the door open for drying. If by any chance the liquid or the water has seeped into the magnetron port then it might have clogged and damaged the unit.
Please check this section inside the chamber and dry this soft spot fully before you can try to switch on the microwave.
If this wont work then check the fuse inside the unit and the thermal cut off switch if this has tripped.
Mar 16, 2011 | Vacuums
When I lock (Dyson DC 15 ) upright position the brushes still working
There is a second switch directly adjacent to the ON/OFF switch. This turns power on and off for the burshbar. Please check this switch is in the off position.
If the switch is definitely in the off position and the brushbar continues to run with the vacuum in the upright position, then the brushbar switch has failed in the closed (power on) position and will most likely need to be replaced.
Please check this and post back if you need further assistance.
Regards,
BElectric
Feb 12, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Sharp microwave carousel R330J 1100 watt. When the heating cycle is started the microwave light flickers on and off and there is a clicking sound. Initially high voltage fuse blown. replaced fuse and...
Hi and welcome to FixYa. I am Kelly.
1st the model number appears to be incomplete. Not an issue at this point but will be if you need parts.
You most likely have an interlock problem with one of the 2 door switches or the door interlock mechanism is broken.
There are 3 safety interlock micro switches activated by the door. One for the light, one for the Magnetron and one for the control panel power. If the problem persists with the Magnetron disconnected. The Magnetron safety interlock micro switch is supposed to blow the fuse if the unit is energized with the door open. Check continuity of your door interlocks. Pat particular attention to the NC (normally closed), C (Common) and NO (Normally Open) contacts.
NC should read to C and when the switch is activated read open at which time the NO contact will read to C.
I really suspect a bad microswitch.
Thanks for choosing FixYa.
Kelly
Aug 21, 2010 | Vacuums
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
No power
This is a clear indication that your on/off switch is probably gone bad. What happened is probably the handle latch was not properly installed when you replaced it. No worries though, I have written a clear, easy to follow guide on how to replace the on/off switch on your Hoover Windtunnel Self-Propelled upright.
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Pliers
- Hoover Windtunnel Switch For All Upright Models
Step 1. Turn the vacuum cleaner around so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you can remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the vacuum bag door and set the door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose pliers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the back side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope this was helpful.
Chris Jones
GoVacuum.com
May 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Inter-mittent fault
your vacuum has a thermo heat switch that will shut off the power as a safety feature the motor is over heating and the switch is being tripped, take it to your local shop and have it checked its either a blockage or you need to have the motor replaced, Don the Vacuum Doctor Alb,N.M.
Oct 30, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
