Question about Washburn D10sbc Acoustic Guitar
Buzz at the e6 string 11th fret
What size wrench is used to adjust neck. I have some buzzing strings when I play open chords and a dead spot at the high e string at the 11th fret. Can this be adjusted in the neck? The guitar is 10 yrs old and has not recieved any abuse in the past, just a couple of tip overs at floor level.
  • 57 Answers
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Posted on Apr 24, 2010
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
Fret buzz only on E string. Adjusted truss and action, and still buzz. Some relief when I turn bass knob higher than the rest
This sounds like a worn nut groove. The string is sitting too low. Does the buzz happen all the way up the neck or just on open string?
Aug 14, 2013 | Dean Guitars Dean Edge E09M Electric Bass...
How to adjust truss rod on yamaha f335 guitar
Taken from http://www.learnguitarsetups.com
There are a few golden rules when adjusting your truss rod. First, only use the rod to keep your neck as straight as it needs to be...do not use it to adjust your action! Second, only use the proper tools. If you do not know what the proper tool is, check with the manufacturer. Truss rod nuts are easy to strip, and once they're stripped, they are expensive to fix! Finally, do not force anything; an eighth of a turn can make a drastic change. Remember, if the truss rod feels tight or doesn't seem to be doing anything, take it to a professional.
  1. Start by sitting with the guitar in the playing position.
  2. Tune it to pitch if it is not already.
  3. Capo the first fret. If you do not own a capo, you can use your fretting hand.
  4. Next, fret the bass string with your picking hand up near where the neck joins the body. This is typically around the 14th fret, but it may be higher up with some electric guitars. In our example, we'll be using the 20th fret.
  5. Use the string as a straightedge held against the neck which will either bow away, or against the string. This is how you determine the amount of relief in the neck. You can also use a steel ruler placed along the length of the neck, in the same manor.
  6. In our example, the approximate half way point between the 20th fret and the 1st, will be the 7th fret where we will observe the distance between the top of that fret and the bottom of the string (or ruler), as pictured. Notice the gap. Hint: Half way down the neck is often between the 7th-9th frets.
  7. If you have a gap between the top of the fret and the bottom of the string, you likely have a bowed neck. If there is no gap, it is likely either dead straight or back-bowed.
HOW MUCH TO ADJUSTThe bigger the gap, the more relief is in the neck. Normally, we want just a small amount of relief in the neck for optimal playing, about the same as the thickness of a business card or less.
If there is a gap, tighten the truss rod clockwise until you have something closer to what we're after. Slide a business card in between the top of fret and bottom of the string (or ruler). Make sure you are placing the card parallel with the string or ruler. If there is no gap, you may be either dead straight or back bowed, so you will need to loosen the truss rod counter-clockwise to get the results we are after. Hint: If the strings are buzzing in the first few frets and open strings, it is often a clear indication of a back bow.
Remember, do not force anything to get the results you are after. If it is hard to adjust or spins freely you may need professional assistance.
The final step in setting your relief is to test it out! If it feels better, you're done! But take note, straightening the neck may actually make your guitar play worse! Consequently, when the truss rod is tightened, the height of the strings are lowered, which can create string buzz if your guitar isn't setup properly to start. Likewise, it can make a poor fret condition more noticeable. So, if your guitar plays worse after adjusting the neck, it is either too straight for your playing style, or it is a sign that more work is needed. Thankfully, you can easily reverse the changes you've just made if required.
For pictures and further info, visit www.learnguitarsetups.com
Dec 16, 2012 | Yamaha Music
The problem I have with my music man bongo bass 4 strings,,, is that the string 4 at fret 5 sounds very strange as making waves, but it sounds good with the other tones, on the other strings when I play...
Check first it is not hitting or touching the next few frets, in case they are high. Or maybe the 5th fret is low. You could raise the action and/or adjust the neck relief to test this.
If it is not a fret problem, it may be a real dead spot on your bass. If so, it would be regardless of the pickup used and could be heard acoustically if you could hear notes that low easily. Most guitars have notes on the fretboard somwhere that are a little dead. It is due to destructive interference and there is not much that can be done. To happen at the 5th fret is unusual though. Make sure the string is wound properly around the head, and that nothing is loose and actually moving/buzzing when you play the note.
Other causes can be a loose fret, loose bridge parts or a loose neck joint.
Mar 07, 2011 | Music Man Bongo 4-String Bass with 2...
I bought a Hagstrom Ultra Swede which sounded very nice when I first bought it but after 3 months I seem to have alot of tuning problems with it. It has been intonated twice and a new set of heavier...
Considerations:
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
Oct 18, 2010 | Hagstrom Swede Electric Guitar Natural...
Some of my frets do not make any noise when i play them, could you please tell me why this is happening?
You should have NO fret noise if the neck is properly adjusted for string height. If you are getting fret buzz take it into a gutar shop for adjustment.
Google "fret buzz"
Jul 28, 2010 | Fender Squier Std Strat Mn Car
Floyd rose is causing a fret buzz
Raise the saddles on the FR to help take away the fret buzz. Check the neck for curve. If the neck has a VERY slight bow on the fretboard side the strings will be able to vibrate better without buzz. Also might want to step up to a heavier gauge string set if you play in lower tunings.
Dec 05, 2009 | Jackson Dk2m Dinky Electric Guitar
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
Nov 03, 2009 | Washburn D10sbc Acoustic Guitar
No notes on my guitars e string will bend
Hello
Have a look at the neck part where the strings move through that aligning unit which has the 6 slits cut into it where the strings goes through at the top of the guitar neck.
What usually happens, the slits get worked out, thus the strings move fractions closer to the fret board which will result in a muffled sound if you press down on the string you get a fret buzz. This happens when the string touches the fret board on more than one spot.
When you play a solo you can get a muffled sound out of certain strings. This happened to me, i just replaced this unit, very cheap, and all was fixed. Hope this can work.
Best regards
Oct 18, 2009 | Fender Deluxe Strat/Telecaster Hardshell...
String buzzing
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
Washburn D10sbc Acoustic Guitar Logo
306 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Washburn Music Expert? Answer questions, earn points and help others
